now I am a real First Watt guy......
Old 13th May 2011, 08:11 PM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by c2cthomas View Post
...... I don't think ZM is OB kinda guy
ya sure about that .......... ?
http://www.diyaudio.com/forums/multi...light=eminence
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th May 2011, 05:03 AM   #12
anilva is offline anilva  India
Originally Posted by generg View Post
I think more important is if your Fostex have the same efficiency of the tone tubby around 96/97 db.....
and to get more on topic... I tried F1J and F2J on the baffles too... there was considerably more bass with the tone tubbies, but the overall sound is the best with FET input and SemiSouth of Babelfish J2 .....
I did not try, but I think F3 and F4 would be also good candidates for this open baffle. I did not try F3 up to now ( excuse me Gyuri, he sent me two of precious Lu1014, a parcel for you is on the way).....
Thanks. Lowthers are more efficient than fostexs. Will build and check how they sound. May need to tweak attenuation of tone tubby.
DIY F5T, F6, Aleph J, M2 & 45/2A3 DHT SET Amp, Fostex 206 based BLH, Altec 515 LF & 288 HF Onkens, Tannoy HPD Speakers. EMT950, Technics SP10, Garrard 401, TD124 turntables.
Old 14th May 2011, 08:42 AM   #13
Zen Mod's Avatar
Originally Posted by anilva View Post
..... May need to tweak attenuation of tone tubby.
no attenuation in bass range
in my book even attenuation in main range kills something
either go to biamp or
use autoformer for taming bass range or
use autoformer to up main range
resistive attenuator in bass range is good just for finding level of attenuation
Old 14th May 2011, 09:39 AM   #14
generg is offline generg  Germany
generg's Avatar
Hi Zen Mod,
nice to see in the link how you helped Yunick 2007 to get a very good low cost open baffle system....
very interesting lecture for me today to read......
http://www.diyaudio.com/forums/multi...inence-ob.html
the residual problem is the deep bass, I do not miss him up to now, to much details to hear new in the midrange and in the deeeeeeeeeeepness of soundstage, but inevitably the day will come i want to hear at least 40 Hz.....
and the First Wtt is......a really First Class PSS Idea
Old 14th May 2011, 09:57 AM   #15
Zen Mod's Avatar
send me T/S for TTs
I "made" what I made then purely by experience with Eminence drivers in servicing PA gear and some bits form www ; now it's easier - with MJK sheets
usually - more bass goes either with biamp or simply doubling number of them
NB that deepness is different issue , even if with 2 per side they really go little lower
considering your residence ( small room in Vaterland ) maybe chasing mint Canton Plus B ( or similar ) is worth chasing ....
Old 14th May 2011, 10:57 AM   #16
generg's Avatar
Originally Posted by Zen Mod View Post
send me T/S for TTs
Hi Zen Mod,
I went to the tone tubby side
and got these two pictures...
the values are a surprise for me not going down very far....
Old 14th May 2011, 11:00 AM   #17
generg's Avatar
oh sorry Zen Mod it is the wrong speaker model
I am searching further...
it was the green line
Old 14th May 2011, 11:28 AM   #18
Zen Mod's Avatar
interesting graphs
The 12" Alnico Tone Tubby
Old 14th May 2011, 01:09 PM   #19
generg's Avatar
I found it.....
Old 14th May 2011, 01:16 PM   #20
Zen Mod's Avatar
saved in //Generg/OB/
considering PM6A - 8 Ohms , Al coil ?
PM6A Drive Unit
Theile Small Parameters for PM6A with 8 ohm Aluminium Voice Coil DC Resistance of Voice Coil Re 7.4 ohms
Free Air Resonance Fo 61.980 Hz
Emission Piston Area Sd 0.021M
Equivalent Volume Suspension Vas 47.192 Ltrs
Suspension Compliance Cms 753.6 u M/N
Mass of Cone Mmd 7.0 g
Mass of Moving Parts Mms 8.75 g
Force Factor Bl 7.27 T-M
Mechanical Q Factor Qms 1.578
Electrical Q Factor Qes 0.477
Total Q Factor Qts 0.366
Voice Coil Inductance @ 1 kHz Le 148.2 uH
Reference Efficiency No 2.278%
Sound Pressure Level SPL 95.593 Db
what I also need is :
dimensions of OB and exact position of drivers
now I am a real First Watt guy......Hide this!Advertise here!
my 250 watt tube amp can be a 500 watt tube amp for less than 2 bucks plus tubes speakerfritz Tubes / Valves 17 24th October 2013 11:50 PM
Speaker guy vs Amplifier guy gainphile Multi-Way 108 15th November 2010 03:00 AM
new guy here jovial_cynic Introductions 5 20th March 2008 07:17 PM
Combing effects: How real in "real" rooms? smeade1079 Multi-Way 3 10th March 2003 12:32 AM
