An illustrated guide to building an F5 - Page 8 - diyAudio
Old 16th May 2011, 04:03 AM   #71
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by Woody1911a1 View Post
ok what happened to your original build thread 6L6 ? invalid thread ? geez
According to the mod to whom I spoke with, there was a software malfunction, which (for an unknown reason) cloned the thread, and they (the mods) couldn't delete one without modifying the other... So they locked it up and reported the problem to one of the admins, who has probably forgot about it or has in buried in a to-do list.
Hopefully it will get fixed.
Old 16th May 2011, 01:23 PM   #72
merlin2069er's Avatar
Send a message via MSN to merlin2069er
It's kind of hard to get to P1 & P2 once the mosfets and board have been mounted (to reset the pots to 0 ohms).
Isn't setting R11 and/or R12 to 0v DC a good alternative?
Old 16th May 2011, 01:27 PM   #73
cviller is offline cviller  Canada
cviller's Avatar
Only if you want to create smoke.
You need to adjust P1 and P2 down to zero ohms before firing it up!
Old 16th May 2011, 01:34 PM   #74
Ok, I'll dismount the whole board and mosfets.
There are no test point on the front of the board to check the values of the pots?
Old 16th May 2011, 01:44 PM   #75
6L6's Avatar
Turn the trimpots fully counter clockwise until they click. They should be at 0.
Unless you can't put a screwdriver on the pots while installed, there is no reason to dismount the board.
If you do need to take out the board to measure/verify the pot's position, take a pen or thin sharpie and mark the direction you need to turn the pot to make it go down.
Old 16th May 2011, 02:21 PM   #76
cviller's Avatar
I understood it as if the pots could not be reached. If that is the case, I would suggest to make them reachable.
Old 16th May 2011, 02:44 PM   #77
I can reach the pots and turn them no problem. I'll just have to keep turning them counter clock-wise until I hear a click.
Do they keep click when they reach the limit of the pot?
Old 16th May 2011, 02:59 PM   #78
6L6's Avatar
Yes, the pots will click click click at the bottom or top of their range, as the adjustment doohickey clutches.
Plug in your light bulb tester in and fire it up. If the bulb glows for just a teeny bit (as the caps charge) and then get dim, you most likely have the pot adjusted down to zero.
Remove the light bulb tester and turn it on. Hook up your meters and start the bias procedure.
Old 16th May 2011, 03:29 PM   #79
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hey, 6L6
happy to say your other thread is OK again
How to build the F5
Old 16th May 2011, 05:02 PM   #80
I'm new to this forum and have to say that I am completely fascinated.
I'm seriously considering taking the plunge on building the F5 and have a couple questions:
1. I remember reading Nelson has a large stock of cases for First Watt. Is he willing to sell the cases to DIYers on a one off basis?
2. Has anyone done a F5 in a multi-channel system? I.e. 5 channels of F5 amplification in one case with one power supply? This would definitely interest me.
Thanks in advance for your help! -Gordon.
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 11:56 AM
Idiotīs guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
Copyright Đ1999-2017 diyAudio
