An illustrated guide to building an F5 - Page 68 - diyAudio
Old 2nd November 2013, 08:19 PM   #671
pvg320 is offline pvg320  United States
pvg320's Avatar
I did triple-check that Q3 and Q4 are where they should be. Then I checked again after your post. I don't know how to measure MOSFET, but when comparing pin to pin measurements, they compare very closely to the channel that's working.
Looks like Q1, the SK170 BL JFET I pulled, is bad. Would that cause my 17v across R1, though? Or did something blow Q1?
Should I NOT be combining a BL SK170 with the GR SJ74? I had attempted that, based on biasing issues...
Q2
2SJ74 GR
(new)
G to D 8.53k
G to S 8.53k
S to D .03k
(pull)
G to D 8.68k
G to S 8.68k
S to D .04k
Q1
2SK170 BL
(new)
G to D 7.98k
G to S 8.01k
D to S .03k
(pull)
G to D 16R
G to S 13R
D to S 5
Thanks again for any ideas.
Old 2nd November 2013, 09:45 PM   #672
cviller is offline cviller  Canada
cviller's Avatar
Did you also mix GR and BL on your working channel? I don't think it necessarily turns into an issue to mix them, but it might make it more difficult to adjust the bias (your R4 may be insufficient to create sufficient gs voltage for Q4).
My guess would be that you during turn on moved P1 too far away from 0R because you did not see any current and then at some point, Q3 got enough vgs to turn on completely and fried your R1. But that doesn't really explain the broken 2sk170...
Old 2nd November 2013, 11:24 PM   #673
pvg320's Avatar
The working channel is using GR grade in both Q1/Q2 , and it biased up (with 2.2k R3/R4) eventually after many half turn/check/half turn/check cycles.
I was much sloppier with the channel that's not working, and the scenario you describe certainly could have happened.
There are no visible shorts on the front or rear between pads, no stray wire pieces touching the sink, and the V+,V-,In,Out,GND connections to the board all clear each other as well.
Should I replace the bad Q1 and R1, reset P1/P2 to 0R, and see what happens? Or lift/measure something else on the board before applying power again?
Old 4th November 2013, 09:36 AM   #674
cviller's Avatar
Yes, I think it could be worth a try.
Regarding your active device measurements, ohm measures between pins does not tell you a lot about the device - in many cases it tells more about the polarity of your test probes...
Have a look at this for mosfets:
https://www.passdiy.com/project/arti...tching-devices
And e.g. this for jfets:
JFET Matching/Sorting
Old 16th November 2013, 01:57 AM   #675
Hey folks.
Finished my f5 tonight and had some biasing issues. Channel one only goes to .3v with zero offset, so I will increase the values of R3 and R4.
Channel two is where the real problem is. My offset at the output exactly matches the bias voltage. I assume that means my mosfet or jfet are toast. Is there a way to troubleshoot the circuit prior to removing both components?
Thanks for the help.
Old 10th February 2014, 04:10 AM   #676
pvg320's Avatar
After a few pads lifted during troubleshooting, I went ahead rebuilt a new F5 board for my bad channel. Both channels are now biased and running, and it sounds incredible.
I'm running a Rega RP1 -> boozhound phono pre -> 5687 Aikido into the F5 and it's pushing out some fantastic music.
Cviller, thanks for your input and the great boards.
6L6 thanks very much for all of the shared knowledge across all of your build guides. I've got some F4 and Aleph J boards waiting to get into the chassis next...I hope to have better luck with those.
Old 12th February 2014, 08:52 PM   #677
Hi Guys,
Sorry about asking a question about an F4 on this thread - but I do understand its the same wiring on both amps PSU.
I am stuck with wiring my dual mono F4 with 240v AC mains. Please see pic attached. I am not very good with reading schematic drawings. Also one more question what fuse should I use for the AC?
Transformer specs - 2x24 500 VA - Secondary current - 2 x 10.4 A
Dillan
Old 24th May 2014, 01:08 AM   #678
marsupialx's Avatar
I don't know if there is anyone around. Have yet to fire up Peter Daniels F5 boards. Boards stuffed long ago. I'm trying to set trimmer pots to min. Turning them has no effect that i can see. Tried measuring across R5 and R6. No change. Having 4 trimmers behaving identically (2 per board, two boards) leads me to measurement error. If the boards were built following instructions, i.e. pots installed predictably, is counter-clockwise minimum? Thoughts?
Old 24th May 2014, 02:57 AM   #679
6L6 is offline 6L6  United States
6L6's Avatar
Only one is counter-clock. the other is backwards. No, I don't remember which.
Old 24th May 2014, 03:19 AM   #680
marsupialx's Avatar
Pots installed according to silk screen on board. How much change should I expect to see across R5 and R6 when turning the adj. screw? Attachment placed only because it has picture of unstuffed board showing silk screen. Thanks for the help!!
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 12:56 PM
Idiotīs guide to building Pass amps? judge Pass Labs 3 20th December 2004 12:33 AM
Copyright Đ1999-2017 diyAudio
