An illustrated guide to building an F5
Old 6th March 2013, 07:48 PM   #611
KWS1 is offline KWS1  United States
Yes. Ohms
Old 6th March 2013, 08:56 PM   #612
Itsmee is offline Itsmee  England
Itsmee's Avatar
Originally Posted by KWS1 View Post
I am seeing 20 volts at R11 & R12....What is wrong? No smoke....
Could be nothing, depends what your voltage rails are.
One probe..gnd the other at the resistor.
Measure the voltage across R11 & R12.
Red probe connected to +V, black probe to Q3 source/ R11 junction.
Black probe connected to -V, red probe to Q4 source/ R12 junction.
Marra pointed to this earlier.
Old 6th March 2013, 10:11 PM   #613
The voltage ...R11 & R12 20 volts. I hooked it to speakers and drive and it sounds great....I do not understand. I built the Amp Camp.....worked right away.
Old 6th March 2013, 10:17 PM   #614
6L6 is offline 6L6  United States
6L6's Avatar
What's the DC voltage on the speaker jack?
Old 7th March 2013, 12:15 AM   #615
1.3 volts right .95 volts left
Old 7th March 2013, 06:21 AM   #616
AudioSan is offline AudioSan  Norway
you have not measured correct. measure across the Source resistors(R11/R12) one probe on each side of the resistor. and do NOT hook up any speakers until bias and DC offsett is adjusted. you are lucky you did not blow up your speakers.
Old 8th March 2013, 01:04 PM   #617
On one side I have 4.85 & 0.80 on the other....the speaker output is...1.3 volts. I was using old speakers....I have been trying to get this going for along time.
Old 8th March 2013, 01:13 PM   #618
4.85V????? 4.85V/0.47ohm=10.3A. 10.85A*23V=250W dissipation. no way.
to get around 1.3A bias, you will want to see about 0.6V across the Source resistors. and close to 0mV offsett.
Old 8th March 2013, 05:28 PM   #619
Russellc is offline Russellc  United States
Perhaps this is mV?
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre
Old 8th March 2013, 05:31 PM   #620
bnorrish is offline bnorrish  United States
bnorrish's Avatar
What about taking pictures of the DMM and the location of the DMM probes?
An illustrated guide to building an F5Hide this!Advertise here!
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 11:56 AM
Idiotīs guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
