An illustrated guide to building an F5
Old 8th February 2013, 07:46 PM   #601
bnorrish is offline bnorrish  United States
bnorrish's Avatar
Thanks. Those are LEDs. Nice part, a little pricey:
Q14F1BXXB24E Apem | Mouser
I live outside Boston - major snow storm today. Working from home, listening to music for the last 8-9 hours. Sounds awesome.
Old 6th March 2013, 05:58 PM   #602
KWS1 is offline KWS1  United States
Default F5 R11 & R12
I am seeing 20 volts at R11 & R12....What is wrong? No smoke....
Old 6th March 2013, 06:20 PM   #603
Marra is offline Marra  United Kingdom
Is that at or across the resistor? Are the trimmers set to zero?
Old 6th March 2013, 06:37 PM   #604
One probe..gnd the other at the resistor.
Old 6th March 2013, 06:38 PM   #605
6L6 is online now 6L6  United States
6L6's Avatar
Do you have the pots turned all the way down? Are you sure which way they turn? You might have one all the way up...
Also, Check all your solder connections. Especially around the P channel output Fet
Old 6th March 2013, 06:42 PM   #606
I am unable to get behind the pot to zero .... I think clockwise increase.. I will check the solder connections... Thanks
Old 6th March 2013, 06:50 PM   #607
6L6's Avatar
Clockwise or counter-clock increaseis a function of how the PCB attached to the pot, so it's not necessarily logical.
Twist for minimum resistance across R5 and R6
Old 6th March 2013, 06:56 PM   #608
I would recommend connecting your Dmm across R5[2k2] powered down of course and turn the trimmers which ever way gets you to zero.You might only get down to about 3/4 ohms which is as far down as mine went.
6L6 beat me to it.
Old 6th March 2013, 08:19 PM   #609
There is no change ......both trimmers have no effect. I checked the solder connections....everything looks ok
Old 6th March 2013, 08:21 PM   #610
6L6's Avatar
Do you have your DMM set to ohms ?
An illustrated guide to building an F5Hide this!Advertise here!
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 12:56 PM
Idiotīs guide to building Pass amps? judge Pass Labs 3 20th December 2004 12:33 AM
Copyright ©1999-2017 diyAudio
