An illustrated guide to building an F5
Old 15th November 2012, 01:43 PM   #561
ssmith is offline ssmith  Kenya
Originally Posted by AudioSan View Post
another solution is a F5 mini. running on +/-15V and 0.8A bias. with a J-fet boz preamp.
that will give you alot of good sound for a smal amount of power.
Sorry to jump in on this thread.
Terrific reading by the way with great build photos -- thanks! -- and it's really given me the urge to try an F5 build as my next project. I built some Mini A's a few years ago (they're in storage right now) but havent been here in ages and havent done any DIYing either.
The F5 looks like a great build and I spotted AudioSan's post on using a transformer with 15v secondaries -- which I can take from my Mini A's. I would love this as it would save quite a bit of money. But I'm really a beginner, so have to ask if there would be big changes in the circuit using a 15v toroid instead of an 18v ???? Also, what would the approximate output power be? My Mini A's were around 10w into 8ohms IIRC and I never felt I lacked power!
Thanks for any advice!
Old 15th November 2012, 01:55 PM   #562
AudioSan is offline AudioSan  Norway
hello. no changes needed in the circuit. output will be around 17-18W at 8ohm and 1-1.1A bias to make it stay in classA.
Old 15th November 2012, 03:21 PM   #563
Thanks AudioSan, that's great to know.
Old 25th November 2012, 05:04 PM   #564
IZHAKKATZ is offline IZHAKKATZ  Israel
Hi all,
Me again with still more problems
It took a while but I finally received new fjets (Q1 & 2) and installed them.(thank you Spencer)
At first turning P1 & 2 Igot no response. I turned off the amp and then turned on again and R12 started smoking...
Please help- what's next? Changing Q4?
Old 12th December 2012, 06:45 PM   #565
Blink_PT is offline Blink_PT  Portugal
Blink_PT's Avatar
Originally Posted by IZHAKKATZ View Post
Hi all,
Review the back of the pcb, burned the R12 is likely to have burnt some clue circuit...
Old 13th December 2012, 10:36 AM   #566
HVfanatic is offline HVfanatic  Germany
Sorry for rushing in:
I replaced ZTX450 with BC550. ZTX is CBE, while BC is EBC. Is this correct??? Just turn the transistor???
Regs, Dirk
Old 13th December 2012, 12:41 PM   #567
Sorry for the stupid question. Found the answer. Will fix it. ;-)
Old 13th December 2012, 01:39 PM   #568
augustoriodosul is offline augustoriodosul  Brazil
augustoriodosul's Avatar
Smile Six F5 together with power supply SMPS
Presenting the assembly of six units F5 in one case. The result is very good for use in mids and highs - multi amplification system.
Invite friends and users look: https://www.facebook.com/media/set/?...4163418&type=1
Old 13th December 2012, 01:52 PM   #569
I am surprised how small the smoothing is.
I think I can read 22mF. Is that 22mF*3 per rail? For all six F5!
regards Andrew T.
Old 13th December 2012, 02:01 PM   #570
dazed2 is offline dazed2  Canada
where do you get those heatsinks! Very Nice!
An illustrated guide to building an F5Hide this!Advertise here!
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 12:56 PM
Idiotīs guide to building Pass amps? judge Pass Labs 3 20th December 2004 12:33 AM
