An illustrated guide to building an F5 - Page 56 - diyAudio
Old 21st October 2012, 12:18 PM   #551
Itsmee is offline Itsmee  England
Itsmee's Avatar
Originally Posted by IZHAKKATZ View Post
resistance in R4 is drifting and not stable
Thats probably due to the thermistor being in parallel with P2//R4.
The bias problem is unusual, people usually have problems biasing the IRFP9240 (Q3).
If you can adjust P2 to maximum resistance and are not getting any voltage across R12, what is the gate-source voltage of Q4? If its more than the gate-source voltage of Q3, Q4 is probably dead.
Old 21st October 2012, 01:20 PM   #552
AndrewT is online now AndrewT  Scotland
.................. now one leg of Q2 does contact one leg of TH2
The legs/leads of the thermistor should be electrically insulated.
The body of TH should touch the output device.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd October 2012, 02:51 PM   #553
Hey guys
Thank you so much for trying to help !
I followed your steps itsmee:
P2 to max, 5.3K
V on R12 is "0"
and like you said, gate to source V (between the outer legs) is higher on Q3 (3V compered to 0.006V on Q4)
I have no idea how Q4 could have died...
Thanks again, hopfully things will work after I'll get a new IRFP240
Old 22nd October 2012, 04:02 PM   #554
bobodioulasso's Avatar
You need to check your input jfets prior to replace mosfet.
Old 22nd October 2012, 04:07 PM   #555
For instance:
Old 22nd October 2012, 06:14 PM   #556
Itsmee's Avatar
That can be done using some rough and ready checks with the JFETS in circuit.
DC check.
If there is a voltage across R1 & R2, Q1 & Q2 are conducting current, the voltages should be approximately equal.
AC check.
Fit a shorting link across the gate-source of Q3 & Q4, set P1 & P2 to mid point resistance, apply a signal to the input and scope the drains of Q1 & Q2 (or measure with a multimeter set for AC volts).
Reset P1 & P2 to minimum resistance before removing the gate-source shorting links.
Old 22nd October 2012, 06:24 PM   #557
If you short g-s of Q3 and Q4 you also short the pots (across 47 ohms).
What's the point?
Better to unsolder the mosfets to check jfets in circuit.
Old 22nd October 2012, 06:40 PM   #558
Itsmee's Avatar
Correct, you have ~47 Ohms to develop a signal across, the signal at the drains will be approximately 4.7 times larger than the input signal, this will show if the JFETS are working or not.
Old 22nd October 2012, 07:26 PM   #559
a.wayne is offline a.wayne  United States
Sin Bin
Hey do you guys remember who had built the 3 pr output F5 ..?
Old 23rd October 2012, 11:31 AM   #560
Itsmee's Avatar
I belive it was Juma.F5 with 2SK2013/2SJ313
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 11:56 AM
Idiotīs guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
Copyright Đ1999-2017 diyAudio
