#501 |
Not with a pot per se, but I have used an iPod and it runs quite well. It won't get full output, but for my purposes I haven't been wanting.
#502 | |
Russellc
Pass DIY B-1, Pass DIY F-5 |
#503 |
is choosing a less facetious title...
#504 |
#505 | |
Russellc
#506 |
#507 |
Oh, you mean the B1 is a no gain preamp, right?
#508 |
If you decide to use a pot alone, as a passive pre-amp, then that decision carries with it the acceptance that the pot output impedance needs lot's of skill and experience to get good performance from the system.
If you don't understand my previous statement then you should not be using a passive pot as a pre-amp. |
#509 |
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Kofi,
Post 53 by Jumna in the thread preamp ideas for f5 is tiny simple and sounds good to my ears. I have a preamp that uses his circuit for a couple of inputs and uses a DCB1 for the others so I have choices..... Evan Juma not jumna
http://www.evancotler.com |
#510 |
Common, Kofi has people to look for him, he never learned how to do that himself.
http://www.diyaudio.com/forums/attac...pre4f5-sch.gif (typical, sooner or later, all these united window types pop up at the Solid State section)
Not so much,.......if it says "ZM" in the corner. |
| F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 | NYCOne | Pass Labs | 123 | 29th September 2011 12:04 AM |
| Idiot´s guide to building Pass amps? | judge | Pass Labs | 3 | 19th December 2004 11:33 PM |
