An illustrated guide to building an F5
Old 25th September 2012, 12:19 AM   #491
KWS1 is offline KWS1  United States
I set up the 3 meters today...it appears there is no voltage at all. The power supply seems to work. what is the best way to move forward. What should I be checking ...first. I have worked with tubes however I have no idea where to begin. Could some of the transisters be backwards? ...or the the power mosfets. is there some order for troubleshooting. Thanks for any help.
Old 25th September 2012, 02:37 AM   #492
6L6 is offline 6L6  United States
6L6's Avatar
Just to verify a few things-
Your PSU is measuring correctly?
Your meters are on DC volts?
You a meter across R11, another across R12, and one on the outputs?
If the PSU is good, and measures properly, you need to start turning up the bias pots. turn them up until you have some voltage across the resistors, and then twiddle with it until you have no offset. Increase the bias, and null the offset.
Continue to do this until you are up to .55v with zero offset.
Then you put the lid on and let it cook for at least an hour, and check your bias. Tweak up to .6v and you should be done. Recheck in a week or so.
Old 25th September 2012, 02:51 AM   #493
I had one on the PSU + ...about 25 volts...one across R12...and one on the output. I read your instructions. It seems like there are lots of turns and no indication of voltage. If I was far off would it read Zero. I should move the output meter to R11...That may be my problem. I also noticed the 25 volts shows the minus on the meter but not the plus for the plus. Thanks for your help
Old 25th September 2012, 10:17 AM   #494
AudioSan is offline AudioSan  Norway
you do not have a bulb tester connected?
Old 26th September 2012, 02:20 PM   #495
6L6's Avatar
KWS1 -- Any news or progress?
Old 26th September 2012, 06:38 PM   #496
I went through the PCB and checked the joints along with the transistor
placement. Everything looked ok. I turned on...one meter went to 1250 and then went down slowly to zero...the other meter was zero. I then checked the voltage at the amp pcb. V + to V- was only 42 volts and V+ was 16 volts and V- was 5 or 6 volts. I now think something is not right in the power supply. I will take photo, or both PCB,s
Old 26th September 2012, 06:54 PM   #497
The Boards are a mess....
Old 26th September 2012, 06:56 PM   #498
R.I.P.
buy components that fit the PCBs.
regards Andrew T.
Old 26th September 2012, 07:01 PM   #499
Thats a good idea...I had the parts before I had the boards...I ordered the PCB from the DIY Store but then there was a problem with the power board so I switched to this PCB.
Old 27th September 2012, 06:25 PM   #500
Kofi Annan is offline Kofi Annan  United States
Kofi Annan's Avatar
Is an active preamp required with the F5 or is anyone using it with a plain old pot?
Thanks!
Kofi
An illustrated guide to building an F5Hide this!Advertise here!
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 11:56 AM
Idiotīs guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
