An illustrated guide to building an F5
Old 11th May 2011, 05:48 PM   #41
cviller is offline cviller  Canada
cviller's Avatar
Originally Posted by merlin2069er View Post
here's my setup so far...
[/IMG]
Edit: on a closer look, I think marra is right... plus to V- is not good.
Old 11th May 2011, 05:52 PM   #42
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
115 mains.
antek 4218.
http://www.antekinc.com/pdf/AN-4218.pdf
Old 11th May 2011, 05:55 PM   #43
6L6 is offline 6L6  United States
6L6's Avatar
merlin2069er - Yes, your primaries are connected incorrectly. And the AC. I can't comment to the PCB connections because I'm not familiar with the layout of the board.
Hang on for a little while longer I can draw all of it out for you this evening, but I must take my son to his swimming lesson right now!
You are very close, just a few re-arangements on your terminal strip and you will be there!!
Old 11th May 2011, 05:55 PM   #44
I've got the bridge + going to v-in -. & bridge - into psu gnd.
Old 11th May 2011, 05:58 PM   #45
cviller's Avatar
How much smoke did you see and do you have any idea where it came from.
Btw. I edited my response above. If you mains connection is correct, you could try to swap the + and - on the V- bridge and fire it up again. Do you have a variac?
Old 11th May 2011, 05:59 PM   #46
oh damn , I should have bridge + going to gnd. Your right.
Old 11th May 2011, 06:02 PM   #47
It was a small quick poof, not that big - I got it because I had the resistors in the wrong spot.
ok, I see where I've made my mistake. I've got the light bulb on power cord.
But, I'll have to pick up additional fuses, I've blown them all.
Old 11th May 2011, 07:05 PM   #48
I've colored the wires, it's should be crystal clear.
Old 11th May 2011, 07:20 PM   #49
cviller's Avatar
Yeah - the mains wiring look correct.
Old 11th May 2011, 09:44 PM   #50
6L6's Avatar
That's not correct. (Although you do have the secondaries colored properly.) The primaries have one red lead and one black lead each.
Here is the AnTek datasheet -
An illustrated guide to building an F5Hide this!Advertise here!
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 11:56 AM
Idiotīs guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
