An illustrated guide to building an F5 - Page 17 - diyAudio
Old 22nd June 2011, 07:01 PM   #161
Itsmee is offline Itsmee  England
Itsmee's Avatar
Originally Posted by Cassiel View Post
Just to clarify: I have a ZETEX ZRA6045F in the PS. I only "need" the CL-60 fron PS to chassis ground. I was hoping to finish this beast before weekend - I don't want to order one. Can I use a resistor instead?
* Not in the best mood for silly jokes. Damn, I hate chassis work.
Yes, any value between 10 & 100R, put a capacitor in parallel with it.
Some prefer to use anti-parallel diodes - use a bridge rectifier, short the + & - pins together, connect one AC pin to 0V and the other AC pin to chassis.
Old 22nd June 2011, 07:08 PM   #162
Cassiel is offline Cassiel  Libya
Thanks!
Old 22nd June 2011, 07:22 PM   #163
what type of wire did you use from the mosfets to the PCB board? My construction technique is similar to yours
I used silver wire diameter of 0.8 cm
Cāble Nu Argent-Or-Cuivre - Cāble Pur Argent 99.999% 0.8mm
Old 22nd June 2011, 08:51 PM   #164
Thanks for the info Alberto. Erm...just another question (), the thermal grease between the mosfet and the mica or between the mica and the heatsink?
I will post pics of the amp next week if all goes well.
Old 22nd June 2011, 09:09 PM   #165
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
grease :
between mosfet and mica
and
between mica and htsnk
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 22nd June 2011, 09:48 PM   #166
I see, everything well lubricated. Game on!
Looking forward to your fugly comment.
Old 22nd June 2011, 10:11 PM   #167
the feast of grease!
The thermal paste used to fill all the micropores
Old 22nd June 2011, 10:39 PM   #168
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
if youwant to see how much(or little) grease you need, mount one up, and dismantle again, carefully
you should be able to if there are air 'pockets'
but I think the rule of 'less is more' counts
Old 1st July 2011, 01:43 PM   #169
Blowing fuses left and right! Some blow themselves up, others see a bright white light before dying. No shorts and my bridges are OK, it's got to be the solid state relay. Do these things blow fuses when testing the power supply unloaded? Should I load the power supply and see what happens? HELP!
The SSR is old and can't find data but it was working allright. Input says 240VAC and 'CONTROL' says 80-280VAC. It was workimg in an amplifier fitted with a 35-0-35 torodial. Should I get rid of this and buy CL-60's? It is OK to test the amp with no inrush current limiters for a couple of weeks? HELP!
Old 1st July 2011, 01:52 PM   #170
use a bulb tester for all mains power ups while you are still experimenting with any mains powered project.
regards Andrew T.
Sent from my desktop computer using a keyboard
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 12:56 PM
Idiot“s guide to building Pass amps? judge Pass Labs 3 20th December 2004 12:33 AM
Copyright ©1999-2017 diyAudio
