An illustrated guide to building an F5
Old 6th June 2011, 11:54 AM   #131
3GGG is offline 3GGG  Australia
Nice Approach, they look great
Old 6th June 2011, 12:32 PM   #132
6L6 is offline 6L6  United States
6L6's Avatar
Wow. Those are the among the best looking F5 ever made!
Very, very nice.
Old 7th June 2011, 02:00 AM   #133
CanAm Man is offline CanAm Man  United States
Plexiglass cover, and blue LEDs. Nice touch! LOL........
How are your heatsinks and temps doing? Looks as though the amp board placement doesn't make optimal use of the sinks (i.e., boards not centrally located on the heatsinks).
Great construction!
Old 7th June 2011, 04:47 AM   #134
anilva is offline anilva  India
Very nice build. Where did you get the power switch from? I am looking for something like that for my F5....
With one Mosfet per heatsink, I am sure they are running quite cool. With 300VA toroid and heatsinks in a monobloc, you can afford to add another pair of output MOSFETs and run warm.
Cheers.
DIY F5T, F6, Aleph J, M2 & 45/2A3 DHT SET Amp, Fostex 206 based BLH, Altec 515 LF & 288 HF Onkens, Tannoy HPD Speakers. EMT950, Technics SP10, Garrard 401, TD124 turntables.
Old 7th June 2011, 09:23 AM   #135
albertob is offline albertob  Spain
Thank you all for your comments and help and especially NP for its design.
I have no thermometer to measure but I can hold my hand forever in the sink. Here in Sevilla (Andalucia) makes a lot of heat. Inside my house at least 30 degrees and was more than 40 º. I put a mosfet heat sink for this reason.
The mosfet is not centered on the sink. There are more heat behind than in front. Surely it would have been better to focus but preferred to have the F5 pcb near the audio inputs and outputs.
Interrupteurs - Audiophonics - Câbles, Amplificateurs et Accessoires DIY
How do I add another mosfet?, what are the benefits?
excuse my English
Br
AL
Old 7th June 2011, 10:31 AM   #136
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by albertob View Post
Here in Sevilla
Damn, i'm good.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 7th June 2011, 11:18 AM   #137
excuse my English
Br
AL
Thanks for the switch details.
Regarding adding one more pair of outputs, there are quite a few schematics in the F5 thread particularly from zenmod, jacco, juma and others on how to parallel the output MOSFETs. Essentially you need matched N-N-P-P MOSFETs and some including me have used Toshiba MOSFETs.
Old 7th June 2011, 03:28 PM   #138
Andy5112405 is offline Andy5112405  United Kingdom
Banned
Originally Posted by Zen Mod View Post
Fugly!
That's personal taste. Not too sure that I would have made them transparent.
Have you seen my thread on the Aleph 4 Strictly DIY build.
They are nearing completion now.
Old 7th June 2011, 04:46 PM   #139
Banned
I'm selling 26 x IRFP244s from International Rectifier that have been through the matching process and are supplied with the data obtained during matching. There are easy pickings for pairs and triplets of 1% matched devices.
£50.00 the lot plus P&P.
Old 7th June 2011, 05:04 PM   #140
Bksabath is offline Bksabath  United Kingdom
Banned
Albertob
Parralel devices is easy Just source resistor 0.47R and gate resistor 47 R
Es lo mismo dos Mosfets dos 0.47 R dos 47 R
Advantages 2 devices sharing the current (this to keep all Power suply the same)
less heat on each device beter use of heath sink.
2 or more devices hi bias better output on low impedance speakers.Voltagge same.
2 or more devices hi biass hi voltagge just more power out.
But not just as IMO (opinion personal) much beter dinamics and slam from mosfets sound much beter more open and faster only snag maybe even more analitic so if you got bad records sell them on.
It all depends on the heat sink, limit is maybe 50W device. (for standard sinks)
I got big sinks so 200W dissipation whitout problems.
If your sinks are cold you could try to up Bias a bit but I would definetly cek the temperature of the mosfets cases first.
If you have poor thermal coupling between mosfets and sinks the sink stay cold and the mosfet eventualy pop.
An illustrated guide to building an F5Hide this!Advertise here!
F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 NYCOne Pass Labs 124 30th May 2016 11:56 AM
Idiot´s guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
