How hot is your BZLS ?
Old 11th August 2003, 10:50 AM   #1
till is offline till
Banned
Default How hot is your BZLS ?
I have measured 110C at th regulator heatsinks and 90C at the gainstage heatsinks. Als resistors and PCB is very hot! It runs for some hours until now without failure....
Old 11th August 2003, 11:21 AM   #2
jh6you is offline jh6you
Account Disabled
Your heat sinks look too small.
That's why I use the whole aluminum chassiss as a heat sink for all transistors.
My amp just does warm operation.
Old 11th August 2003, 11:42 AM   #3
grataku is offline grataku  United States
Default Re: How hot is your BZLS ?
That's nothing new.
Read my posts in one of the BLS threads about 1 1/2 years ago
Old 11th August 2003, 12:10 PM   #4
Banned
grataku, this one?
http://www.diyaudio.com/forums/showt...1820#post11820
jh6you,
The heatsinks are 13.5K/W types. There is no space for larger ones om the PCB if mounted the way the PCB is made for. They look same size like in the article. My only change is 680R instead of 750R, because 750R i did not find here. This may be responsible for a little more current.
Old 11th August 2003, 12:44 PM   #5
There are probably even earlier posts, there I had already replaced heatsinks, I think. Anyway, 680 ohm instead of 750 will heat things up a little more not too much more.
I would start thinking about replacing the heatsinks for something bigger.
The nice thing about this site is that everything has been done and reported, the problem with this site is the search engine, it's very hard to do organize the database. If someone could come up with a way to do it he or she would make big $$$.
Old 11th August 2003, 12:53 PM   #6
Banned
you are absolutely right about the search engine. You search - find nothing. Redefine search string - find 3 pages with threads. Look into the thread - thread ist 598 posts long. Look and find nothing. Go to print view, go to show all 598 post of this thread on one page, use your browsers string search, and find something if you are lucky. But you will need a lot of time to do this with all the 3 pages of threads, so you will not find everything ....
Old 11th August 2003, 01:44 PM   #7
UrSv is offline UrSv  Sweden
UrSv's Avatar
Sorry to continue OT but you can actually display a whole thread in one page? I thought that was removed as the per_page option did not work. And what is "print view"?
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 11th August 2003, 03:03 PM   #8
Goffe is offline Goffe  Sweden
This is mine version of BZLS and the aluminium sheet gets warm but not hot!
And u can touch the components for 3 sec or more without Burn u finger down !
This is my first Tread..hope it works!!!
Old 11th August 2003, 03:20 PM   #9
Bricolo is offline Bricolo  France
Bricolo's Avatar
print view is the option at the page's bottom: "show printable version"
then, at the top right of the printable version, click on "show all xxx posts in one page"
Old 11th August 2003, 04:59 PM   #10
Banned
Hi Goffe,
did you try to attach a picture or link?
How hot is your BZLS ?Hide this!Advertise here!
CC-CCS-X-BZLS: It's alive! metalman Pass Labs 130 27th October 2009 03:38 AM
BZLS pre-amp garfieldcat Pass Labs 4 4th July 2005 08:38 AM
x-bzls finished! coils Pass Labs 33 16th August 2004 11:09 PM
Help needed with BZLS franck_chretien Pass Labs 2 13th February 2002 05:58 AM
Copyright ©1999-2017 diyAudio
