diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Balanced audio technology VK500/1000: "Single-Ended Bridge" Topology, 450W into 4 Ohm (http://www.diyaudio.com/forums/pass-labs/188487-balanced-audio-technology-vk500-1000-single-ended-bridge-topology-450w-into-4-ohm.html)
tiefbassuebertr 5th May 2011 09:57 PM
6 Attachment(s)
About
http://www.balanced.com/resources/br.../VK500desc.pdf
I read:
A typical solid-state amplifier
will have four or five gain stages, with a feedback loop traversing these same
stages to correct the signal. The VK-500 uses only two gain stages—without
global feedback. Unusually direct for any amplifier, this purist signal path is even
more surprising in a design of such high power. The ingenuity of the signal
path is complemented by a unique single-ended bridge topology that allows the
use of superior N-channel MOSFETs in both driver and output stages. The
result is a clear, open sound that breathes life into music.
This sounds like a design from Mr. Nelson Pass.
Also the review about
Balanced Audio Technology VK-500 Reviews
and
Product Review
Perhaps a transition from a "ZEN"-topology to a "CSPP" (Circlotron)??
Who knows more about BAT's topology?
banat 8th May 2011 06:04 PM
Yes , it is always employed Balanced Bridge / PPP ( Circlotron ) topology inside of this ( Viktor`s ) BAT SS or Tube PP Amp .
Best Regards
tiefbassuebertr 10th August 2011 10:12 PM
are anywhere schematics for download?
mr l 10th August 2011 10:54 PM
like krell, they don't release schematics. good luck!
a.wayne 12th August 2011 12:24 AM
Had a Pr ... not a fan .....................:(
tiefbassuebertr 12th August 2011 06:34 PM
I don't need a detailled schematic diagram, only a simlified schematic like that one from the Pass Aleph on page 5 about
http://peufeu.free.fr/audio/schemas/Pass_Aleph_3.pdf
Nelson Pass 12th August 2011 10:25 PM
The phrase "balanced single-ended", first used IIRC by Bel Canto, and an
oxymoron if there ever was one, is nevertheless pretty descriptive.
It is likely:
1) Circlotron, either Common-Drain or Common-Source.
2) Two conventional single-ended output stages operated in balanced mode,
either Common-Drain or Common-Source, biased by a CCS or variable
current source.
3) If the product is advertised as lacking global feedback, then it very likely
is a Common-Drain version of 1 or 2
:cool:
(Fet pin references. Your pins may vary)
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
