Old 10th August 2003, 01:47 PM   #1
Default How to connect the blue led ? ;-)
my Aleph-X is finished, here some pictures before all wires were connected and the lit closed...
One question; with the old Aleph the blue led is connected over the active current source. However the Aleph-X has two of them, how do you connect the led to get superior sound quality without getting the source out of balance ?
For the statistics see a previous thread!
Bye,
Edwin
Old 10th August 2003, 02:05 PM   #2
Banned
stay away from those blue LEDs! they totaly kill the sound! If you want the real sound - use a 6E5 tube instead! It can also show you the accuracy of sound the amp produces at the moment - a great control instruments.
Old 10th August 2003, 02:59 PM   #3
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Yeah, definitely watch out for led's. They can be very noisy!
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 10th August 2003, 03:24 PM   #4
Netlist is offline Netlist  Belgium
Netlist's Avatar
Default Re: How to connect the blue led ? ;-)
Hi Edwin
Good to see you're back with your fine-looking amp.
I see some people warn you not to implement a led.
They could be right, they could be wrong.
Anyway, here's a nice thread with a lot of possible ways to connect a LED: Blue LED for BOSOZ, how to implement?
Are you still happy with the sound?
And get rid of the DC?
Greetings
/Hugo
Old 10th August 2003, 07:50 PM   #5
Default LED Connection
I have gone to the simpler is better school. In my circuits I run a blue LED from each + and - rail. The LED's used are 3.5 volt and are plenty bright a 10ma.
The value resistor needed to drop each rail to 10ma is added at each end of the diode. This way there are 4 resistors used to connect two diodes. The resistors sghould help buffer the noise from the diode.
Placing one across the current source looks great, but this can add noise. The wire wrapped around the transformer looked good to me also. Then looking at my Plitron's it was more trouble than it is worth. A diode circuit and all.
BTW, Great looking amp.
George
Old 10th August 2003, 07:58 PM   #6
W.O.L.F.'s Avatar
Hi Edwin,
if you need blue led, run it from 110V/230V. You need only some parts to do that....
Reinhard
Old 18th August 2003, 12:27 PM   #7
Bricolo is offline Bricolo  France
Bricolo's Avatar
Originally posted by W.O.L.F.
Hi Edwin,
Reinhard
does it introduce less noise?
Old 18th August 2003, 02:24 PM   #8
Netlist's Avatar
Default LEDTest
Why not perform a simple test:
Connect a scope at the output and look at the result with and without the LED.
This should give us an idea of the added noise.
/Hugo - will try it one of these days.
Old 18th August 2003, 04:08 PM   #9
Electrons are yellow and more is better!
peranders's Avatar
The amp itself isn't a very low noise amp.
I prefer UV LED's Nice invisible light.
BTW: Do they emitt any visible light?
BTW 2: Very nice looking amp!
/Per-Anders (my first name) or P-A as my friends call me
Old 18th August 2003, 06:55 PM   #10
thanks for all the postings... However I was only kidding about the led's !!! It was a funny way to show off my new amp pictures!!!
I just connected the blue led to one of the current sources (I do not here any audiable difference) (one led per channel)...
Edwin
Big Blue Saw Rob M Everything Else 1 26th January 2007 07:00 PM
Blue LED's in the CDP Bryan Digital Source 10 23rd March 2005 11:05 AM
BLue hue Brap Tubes / Valves 8 20th March 2004 04:25 AM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Page generated in 0.10478 seconds (79.31% PHP - 20.69% MySQL) with 10 queries
