new f5 bias problem
new f5 bias problem
Old 30th April 2011, 07:10 AM   #1
crazycody1993 is offline crazycody1993  United States
Default new f5 bias problem
So i've been watching everyone do their F5 builds, and it looks like everyone is doing awesome! not a whole lot of issues, just small things, hat you can turn the amp off, swap something out, and turn it back on, and go to town!
But i've run into an issue that i haven't seen yet.
I'm in the process of trying to get my amp to bias properly, doing one channel at a time. but on one of the channels, as soon as i turn the amp on, R14 instantly bursts into flames! i've replaced it twice now, and i cant seem to find the issue, and was hoping someone would have an answer for me. i dont know if i have my trimmers the wrong direction? everywhere i've read, you set it to 0 ohms, and work your way up, monitering voltages across R11 and R12.
maybe i have any of the transistors backwards?
any information will be greatly appreciated,
Thank you early
Cody
Old 30th April 2011, 07:34 AM   #2
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
new f5 bias problem
my crystal ball is muddy these dayz ( I confess - I'm lazy )........ so - will you enclose some pictures and further info ?
pretty please ........
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 30th April 2011, 09:21 AM   #3
Itsmee is offline Itsmee  England
Itsmee's Avatar
R14 is the gate resistor, if P2 is at min resistance, that connects one end of R14 to -V, for current to flow, there must be a fault/short around the IRFP240
Old 30th April 2011, 09:56 AM   #4
Itsmee's Avatar
When you have found the fault, check that P2 has not been damaged from the current flow before powering up again.
Old 30th April 2011, 03:24 PM   #5
qusp is offline qusp  Australia
qusp's Avatar
yes, pictures would do nicely, sometimes i have trouble reading just words without them
Old 30th April 2011, 03:31 PM   #6
Itsmee's Avatar
F5
Old 30th April 2011, 03:46 PM   #7
i know i have knock off boards, and would like to apologize to everyone appropriatly. i have great respect for all of you, and at the time of purchasing, didnt even know the amplifier was an F5, and would have absolutely bought the proper one, if i would have realized.
i guess i should have added some more information, although i thought R14 would be important because it arced to the end of its life, twice in a row. I also had R18 burn shortly after it, when i tried firing it up the first time, as well as R1, and R2 turned to a nice golden brown color.
so i replaced all of these resistors, then ran into R14 the second time, and figured i would ask the experts.
Old 30th April 2011, 04:05 PM   #8
Itsmee's Avatar
Silly question, I cannot tell from the photo, are there insulators between the FETs and heatsink, and how much clearance is there between the PCB and heatsink, I notice that two of the stand offs are mounted on the FETs and two are on top of the PCB.
Old 30th April 2011, 06:12 PM   #9
alazira is offline alazira  United States
alazira's Avatar
I don't recall capacitors in the F5 circuit. What value are they?
Old 30th April 2011, 06:29 PM   #10
Yes, there are insulators. And I believe its close to 1/4 inch standoffs. The reason for the standoffs being on top is because I haven't had time to go get the proper length bolts, being I'm about a half hour from a place that carries that size.
And the capacitors are just on the voltage rails, not anywhere in the actual circuit.
new f5 bias problemHide this!Advertise here!
F5 DC High, Bias Low vdi_nenna Pass Labs 9 5th March 2016 12:04 AM
Initial setting of F5 bias--help, please! CanAm Man Pass Labs 30 23rd June 2014 01:12 PM
F5 bias question richD Pass Labs 12 4th March 2013 12:57 PM
F5 Bias Problem maartentje Pass Labs 150 3rd August 2012 11:10 AM
Bias problem- 1 Socket shows extremely low bias! otokomae Tubes / Valves 12 31st December 2008 10:01 PM
