Hello,
I have build the A-30 mono blocks with brianGT PCB-s 2 years ago You can see the pics here: https://picasaweb.google.com/1078196...eat=directlink They have worked flawlessly for last 2 years and brought many hours of great music enjoyment. Unfortunately yesterday when I fired them up a huge buzz appeared on both channels. Since I was messing around my source and preamp last few days I thought that the problem is there. Investigating further showed that the hum and buzz is unfortunately from the amps... So here is the problem: first with no load at all amps are silent but when I add any kind of balanced source there it is... I measure 147mV AC on speaker connectors. DC is less than 20mV after 2 min. With RCA and jumper across minus and gnd on XLR all is fine... No cap shows shortages no funny smells and I have measured all currents fine Since my knowledge in electronics are limited I just have no idea where to look further? ![]() I have attached the schematic of the boards I have used.
...is I disappear. There is ONLY the music. |
#2 |
RIP
You're not being logical. There is no problem with the amps unless you have done something weird with the grounding in both your sources and the amps. Much more info needed, especially about your sources. How about schematics or drawings?
#3 |
Bill,
Thanks for the reply! I did not want to "overflow" first post with every info and measurement that come into my mind. You say I'm not being logical... I seem unable to find - measure where is the problem but I can surely hear it. So there IS a problem with my amps. And yes... the source... I admit I was playing around my source just few days before... I have a TP buffalo dac with legato1 boards...that I have modified into latest incarnation of legato3 (ref.Legato 3 - Look ma! No caps!). Changes included taking out buffer, piggybacking Supertex TP0604 trios in place of BS250 and the thing I did on my own risk after measuring 0-6mV DC between - and+ I took out the coupling caps without trimming DC to 0 and with no gnd from the source!!! Yes I know should not have done that etc. Such signal was passed threw my pre-amp which is an early incarnation of The Poor Serbian Man's Optical Attenuator It sounded marvelous like never before for one and half day... Gimme a hint where to look first
...is I disappear. There is ONLY the music. Last edited by Bassivus; 30th April 2011 at 07:02 PM. |
#4 | |
Russellc |
#5 | |
Russellc |
#6 |
Yes I did try it with other source. I have connected it and even without powering up the source the humm and buzz is present... That source on the balanced out has Jensen trafos also gnd lifted...
#7 |
few pics will help
I suspect that arrangement of gnd lead is culprit especially if everything is fine with pins 1&3 tied
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#8 |
RIP
I'm sorry, references to other projects is not very helpful. Your implementation is directly connected to your problem so make a detailed drawing of your arrangement so we can help you find your error. I realise that there is a slight language barrier, and it would help troubleshooting greatly.
You have given me the impression that without inputs connected the amps are silent. When you attempt to use the amps' balanced inputs it creates hum, so that would point to your preamp being the problem, not the amps. Is that not the problem? |
#9 |
Zen, a lot of pics on link in my first post...
Brian: Lets forget my setup with preamp etc. I have tried my amps with 3 different sources DIRECTLY to amp and there is a problem with balanced in... Untitled-1.jpg I measure HUGE DC over 16V peak on DMM at the fire up and it very slowly goes down... BrianGT-aleph-schematic.jpg
#10 |
sorry - I didn't saw a link
you know that I'm double blind ![]() anyway - I recently made mistake , which took me 2 hours to solve - swapped gnd and hot neg. on XLR ; be sure that : pin 1 - gnd pin 2 - hot pos. pin 3 - hot neg.
| Wanted: 30-0-30 500VA transformer x 2 (UK/EU) | firestorm | Swap Meet | 0 | 12th January 2011 01:30 PM |
| Premier Speaker Stands ... by Paradigm -- model: S-30 (30"tall) | Livin | Swap Meet | 10 | 3rd February 2009 02:08 PM |
| Q: Zen-lite with -30~+30 voltage rail? | Peter Huang | Pass Labs | 2 | 7th August 2007 11:42 AM |
| [Newbie] Using 50V cap with 30-0-30. safe? | nina | Chip Amps | 19 | 31st August 2005 05:34 PM |
| 2 x 500VA 30-0-30 Toroidal Power Transformers | WALTER BURKHARD | Swap Meet | 4 | 30th July 2005 01:01 PM |
| Page generated in 0.13290 seconds (77.52% PHP - 22.48% MySQL) with 11 queries |
