Single Ended to balanced for F4
Old 24th April 2011, 06:52 PM   #1
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
Default Single Ended to balanced for F4
I'm going to build 2 F4 mono-blocks balanced, to get 100 wpc@8 Ohm, which my loudspeakers would love. 25 wpc@8 Ohm isn't enough for them.
Alas, my preamp and phono stage have only balanced output. So, I need Single Ended to balanced conversion. I\d like it to be all FETs, preferred all FFETs, with no GNFB.
The circuit I came up with is attached.
All comments are welcomed.
Old 24th April 2011, 07:08 PM   #2
Joshua_G's Avatar
P.S,
I also wanted no capacitors in the signal Path.
A DC servo is intended, to keep the outputs at ground DC potential, or zero potential.
Old 24th April 2011, 07:38 PM   #3
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by Joshua_G View Post
Alas, my preamp and phono stage have only balanced output......
typo ?
you meant unbalanced ?
anyway - you need more swing for full throttle F4
that means - you must go with cascodes
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th April 2011, 08:15 PM   #4
Joshua_G's Avatar
Thanks.
Indeed typo, my phono stage and preamp have only single ended outputs.
As for the voltage swing, R18 sets the gain. I changed R18 to 3.3K and now 1 volt at the input gives over 22 volt between the outputs.
Another typo is that I prefer that stage to be all JFETs.
Old 24th April 2011, 08:19 PM   #5
Joshua_G's Avatar
P.S,
The stage in the schematic is folded cascode.
Old 24th April 2011, 08:31 PM   #6
Zen Mod's Avatar
folded yes
but not enough voltage and
not cascoded in right place
Old 24th April 2011, 08:45 PM   #7
Joshua_G's Avatar
Just say how much voltage is needed and R18 will take care of it.
Old 24th April 2011, 08:52 PM   #8
Zen Mod's Avatar
just look what's voltage swing of balanced F4
then take measure that jfets are still in safe voltage area
Papa sez that they're good to 40-43V ..... bit observing dissipation is must , too
Old 24th April 2011, 09:22 PM   #9
Joshua_G's Avatar
As far as I recall, Papa said in the F4 thread that it takes +/-20V. If +/-40V or +/-45V is needed, it can be done with the above schematic by changing the value of R18, which sets the voltage gain of the stage plus maybe raising the supply voltage.
Old 24th April 2011, 09:46 PM   #10
Zen Mod's Avatar
exactly ;
Maximum unclipped output +/-20 Volts (SE)
+/-40 Volts (Balanced Mono)
that means - you need slightly more than 80Vpp for balanced F4
Single Ended to balanced for F4Hide this!Advertise here!
How to add balanced input to single ended amp? jaistanley Class D 5 2nd December 2010 04:29 AM
Single ended to balanced Aikido with mosfets in buffer position exeric Tubes / Valves 0 28th October 2010 07:14 PM
Single-ended input to balanced output, no DC offset LineSource Solid State 16 19th October 2005 09:32 PM
Converting single ended amp to balanced boyelroy Solid State 15 10th November 2002 04:51 PM
Does it Make Sense? Balanced to Single Ended Super_BQ Pass Labs 3 3rd October 2002 09:01 AM
Copyright ©1999-2017 diyAudio
