Does anyone have a pic of this board assembled that they could post? I can't seem to find one of the V2.0, only V1.0. I want to make sure I have everything in the right place and with q5 and q6 in the right orientation.
#2 |
"This is DIY. I view op amps the same way I look at a can of soup or a fast-food burger" NP |
#3 |
I don't see a picture of a populated board there, am I just missing it?
#4 |
you need to check the datasheets for the parts in question . they will make everything very clear .
look up your part # on digikey or mouser and then click on the link for the datasheet . cheers Woody |
#5 |
I checked the data sheet but this is my first amp an want to be sure I did it right. If I can post a pic could someone make sure I assembled it correctly?
#6 |
Dj, sorry about that, I didn't read your post correctly.
Post pics and which parts you are using(ZTX, etc) jim
#7 |
dj , in that case
holding them so the printing is right side up Q6 is on the left and assuming you're using the ZTX450 , the "flat side " should be facing you . Q5 is on the right and assuming ZTX550 the "curved side" should be facing you . hth cheers Woody |
#8 |
Woody that was exactly what I needed to know. Just to be sure Q2 and Q1 should have their flat sides facing each other.
#9 |
I had this same issue a while back but never saw a photo either.
This PDF does have some info you might find handy if you haven't already seen it. I also found this photo of some use. Best of luck Dean Last edited by thunk303; 17th May 2011 at 02:48 AM. |
#10 |
Hmmmmm cant seem to upload PDF. Will PM you
| Looking to swap F5 Boards V1 for V2 | labjr | Swap Meet | 0 | 1st March 2011 05:01 PM |
| FS: F5 PCB fully populated x 2 | dhole | Swap Meet | 13 | 23rd September 2010 12:52 PM |
| FS - Cviller F5 | Neutrality | Swap Meet | 3 | 21st September 2010 09:51 AM |
| FS: Cviller F5 P.C.B with PSU | bchristmas | Swap Meet | 1 | 11th September 2010 02:16 AM |
| cviller f5 board Q5, Q6 orientation? | qboneus | Pass Labs | 2 | 19th August 2009 12:07 AM |
| Page generated in 0.09687 seconds (70.07% PHP - 29.93% MySQL) with 11 queries |
