Hello all,
I am VERY intreagued by these Pass designs, the symmetry simply rings true in my mind, so wouldn't mind having a bash as constructing my own amp based on these wonderfully simple designs (something else which rings true, the simplicity). Hence I like the designs that use simplicity plus super-symmetry (am I right in assuming the Aleph-X?) But! Where to start, so many long threads, so many options, so please allow me to ask the question of where to start! My aim is to produce a 30Watt amp, that will drive some full-range speakers I built (thnx Planet10). I wouldn't mind implementing the Lightspeed attenuator idea into the design too. Hence what PSU / pre-amp / amp combo should I be looking at & where can I find some 'finalized' schematics?? Getting hold of PCBs would be useful too as this would ease the construction pain somewhat. Thanks in advance, Andy |
#2 | |
Better start with something simpler and more final, like the super-popular F5. Less symmetrical but nevertheless cute are the Burning Amps BA1 or BA2. If it has to be an Aleph, the Aleph30 is a good option to start with. As preamp the B1 is favoured by many. F5/BA1/BA2 boards you get from the DIYAudio-store, Aleph30 boards maybe from someoneelse in Swap-meet. Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#3 | |
Andy |
#4 |
Sure!
First of all, the circuit itself is not series production level mature and might need tweaking (e.g. to get acceptable DC-offset) depending on actual circuit and power level. There exist also a number of variations, like with jfet frontend, that have other potential issues as well, like limited number of output fets due to little drain current of the jfet LTP. Also thermal design (thermal coupling of mosfets) plays a role to get stable dc-offset, so good mechanical and thermal construction is well advised. The X'ed amps are also a little sensitive on the impedance at their inputs, so dc-offset might become a small issue depending wether they're driven balanced or single ended. Last, as there exists quite a number of variations, it might be difficult to get professionally made boards for the variation you're interested in, as most do their own board design at this level. Hannes
#5 |
This is the sort of thing you could end up with, not cheap, a project for the dedicated builder. If you are a member of the fearless amp builders, go for it.
Pic is from the AX thread. |
#6 |
Very nice build!
Hannes
#7 |
Just so's you's know's my profession is electronics engineer (high power controllers at Penny & Giles, so using & clamping MOSFETs is my bag, baby
So not much is putting me off the actual 'doing' side of things. I have much kit and bits available to hand as one would expect being in such an industry. Having said that, amps are one of those things I lack experience in, so I take on board what you guys mention re: tuning & matching etc.... Hence the thread question! Cheers, Andy |
#8 |
RIP
In your case I think your best bet is find the original X-amp thread by Grey Rollins and review the progression and development. You will find that a very simple approach will yield over 30 watts per channel, enough for med. efficiency full rangers.
Best, Bill |
#9 |
RIP
"The Aleph-X" is the original thread.
#10 |
I would suggest a look at the F5. It 'checks the box' of your requirements, namely power, simplicity, and symmetry. It is a very popular amplifier right now, and justly so... Everybody who builds it is very pleased with it's performance and quality.
Boards are available from 2 legitimate (and authorized) sources, and there are stolen, pirated rip-offs from that auction site. Many people have built the amp on this forum, so you will find plenty of resource and help. Here is the manual, written my Nelson Pass. It is in 2 parts, the 'owners manual' in the beginning, and the 'how-to' after that. http://firstwatt.com/pdf/prod_f5_man.pdf
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
| Output Transformers... Decisions Decisions | RTF671 | Tubes / Valves | 10 | 27th February 2011 12:42 PM |
| SEDHT amp - decisions decisions | mobyd | Tubes / Valves | 1 | 21st August 2010 03:13 AM |
| Decisions, Decisions - Help me select iron | kstylianos | Tubes / Valves | 7 | 14th February 2006 12:05 AM |
| Home Theater Combo - choices choices | smithsonga | Multi-Way | 1 | 2nd April 2003 05:11 AM |
| Page generated in 0.10356 seconds (80.85% PHP - 19.15% MySQL) with 11 queries |
