Aleph X with BJT, anyone?
Old 11th November 2011, 07:14 AM   #11
h_a is offline h_a  Europe
h_a's Avatar
In my simulations I have found that I can get a lot closer to the 12v rail voltage using a 2N3055 BJT in the CCS (constant current source)in the top half than I can using the FET's.
You get closer to the rail as BJTs limit rail swing by 1 volt or so (VBE plus little extra) and mosfets eat VGS (3.5 V or so).
Junk box amps are a nice playground! Just keep in mind not to go lower than the 12 V rails as the capacitances in the fets are very non linear below 12-15 V or so.
Hannes
High Octane phono preamp Wiki
Old 11th November 2011, 09:58 PM   #12
geraldfryjr is offline geraldfryjr  United States
Yes,that was was what I had figured out if I were to use a higher power supply voltage this problem goes away.
I am working on the circuit for use on a 12v pc supply so I needed to get as close to the rail that I can.
My first version uses opamps to drive the output Device,So this compensates for most of the non-linearity's even though it is still operating in class A mode.
I also have a fully transistorized version in mind and that will be the one that I will present here in the Pass-Labs Forum when I get it working.
jer
Old 11th November 2011, 10:10 PM   #13
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally Posted by 3nity View Post
Don't know if it works properly.
Possibly the current source would work better as a "mu follower" as the Vce
across the little npn transistor which regulates it is low, and you will see some
non-linearity there. ZM or someone here will point you toward such a circuit
if you don't already know it.
Aleph X with BJT, anyone?Hide this!Advertise here!
Advantage of a FET-BJT CCS vs BJT only Bitrex Tubes / Valves 2 10th June 2009 04:01 AM
Aleph clones using BJT Mambo Pass Labs 4 4th March 2003 10:07 AM
BJT Aleph input Koy Pass Labs 6 24th October 2002 01:54 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 08:55 AM
BJT Aleph Koy Pass Labs 5 9th September 2002 09:52 PM
