#21 |
did I said Fugly! ?
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#22 | |
Interesting considering, too, for speaker enclosures--very easy to apply carbon fiber "rope" (or additional thicknesses of cloth), to strengthen enclosures, and to control internal resonances. Ponder the possibilities! |
#23 | |
P.S. if you cut flat carbon panels, afterwards, hit the edges with 600-grit wet-and-dry sandpaper, followed by about 1000,0r 1600-grit wet. It polishes the cut edge, so it's like butt-ah....!! Use a little rubbing compound and a good caranuba wax on the panel, and you'll have a show piece! |
#24 |
wakoo Ken Mod
#25 |
But audiomaster Zen Mod..... as a "greenhorn grasshopper" I am still learning from you every day......
....and you are a "fellow welder", besides.....!
#26 |
Master Burner
CanAm, thank you for the tips on carbon fibre. This was really my first experience with this material, and I was worried how it is going to be, but figureout, if you cut it with the scizors, it should work well on the mill, and that how it was. It was funny, I was doing something and was sort of pushing the edge of carbon fibre with the wise jaw, and this is really thin sheet just like veneer, and the whole thing was giving serious resistance to the milling wise!!!
Incredible. For someone who is really determined, doing the speaker case with it would be a dream comes through. Open baffle first comes to my mind.I would be very excited to see your future F5 case done out of carbon fibre sheet, that will look awesome. Best AR2
www.burningamp.com |
#27 |
I'll post a pic or two, of what a "homemade" carbon composite flat panel can look like......
Yep, on being able to use common scissors to cut most carbon weaves. I sometimes use a carbon-aramid cloth on cars, or just pure aramid cloth. It comes in very handy for areas that may require puncture resistance (like, the part that goes under your butt, when you are doing 200 mph, with just 4 inches between you and the ground!). This carbon-aramid stuff is painful to cut without special shears. (Aramid is also known by its "Kevlar" brand name--same stuff used in body armor and bullet-proof vests.) I'm thinking it's best to avoid carbon-aramid, unless really needed. For audio use, carbon composite twill weave has a LOT of promise, for a lot of good reasons....and it looks sexy, too......(!) |
#28 |
yup
I remember - they have kevlar blankets wrapped around clutch bell , on tractors made for funny tractor pulling competition they said - before that measure - it happens that pieces of clutch were flying all over the place
#29 |
Some folks, who had a legal dispute with DuPont going for over a decade, would say Aramid is also know by it's "Twaron" brand name.
![]() (easy way to get around US import restriction deals another decade later and become market leader in Aramids, is selling the fibre to a Japanese, but still manufacture the yella stuff within the Cheese borders)
Not so much,.......if it says "ZM" in the corner. |
#30 |
Sadly true, Zen...... I have a friend with a few toes missing, due to a clutch that exploded on him. Kevlar would have really helped.....
| Class A Sounds Mighty Sweet! | jgray | Solid State | 20 | 6th March 2011 09:26 PM |
| "Mighty Mite" Single Ended Amplifier | wrenchone | Tubes / Valves | 13 | 20th October 2008 04:57 AM |
| Question for all mighty ILIMZN and others... | bogdan_borko | Solid State | 36 | 10th February 2006 11:45 AM |
| PHL / ESg 3 way question - AR2 | Branwell | Multi-Way | 39 | 13th March 2005 04:23 AM |
