Aleph Mini riddle makes no sense to me...
Old 4th August 2003, 11:57 AM   #1
MBK is offline MBK  Singapore
Default Aleph Mini riddle makes no sense to me...
So I built a mini-Aleph to experiment with, and thought for use in my biamped system (fullrange 6.5" and woofers, both as dipoles on same panel, with line level active EQ and X/O).
For the circuit I mixed elements of the various iterations available. As usual after buying components I was missing some so I substituted some parts as well.
Implementation now is, one channel built, gain=20, comp caps 1.5nF, feedback R = 20k = input R, IRFP140N, +-24V from the same 375 VA 18-0-18 PSU that feeds the rest of the system, bias 1.6A, AC current gain adjusted at 100 Hz.
Now the riddles. First I listened to this one channel thrown into the system. It's biamped and the three other amps are OPA549, I used the mini Aleph for the left channel's fullrange only.
Result: sounds sweet, but strong/bloated bass. It is even more noticeable when touching the left fullrange's cone: it moves a lot more than the right's fullrange's one driven by the OPA548.
So I measured some simple parameters.
DC offset: high, 100-120 mV. Maybe my poor choice of input tail R of 330R instead of 392R or incometent matching (my best pair of 9610's, matched at 0.01V!!). OK, I accept.
Frequency range: I have a DIY fast peak meter, very precise but pot adjusted, so 1dB is the limit in resolution. Anyway I get flat over the range but -2dB down at 20kHz. Surprise but OK, I accept. (comp. cap 1.5 nF over 20k should give 80kHz cutoff no??).
Output Z: a 6.7V no load output becomes 6.62V into a 13.5 R load(that's what I had lying around...). So I calculate
Zout = R(L) * {V(0)/V(L) - 1} = 0.16 Ohms, OK.
So how come I get uncontrolled bass in a fullrange driver with Fs 80 Hz but cut off at 310 Hz by a 24 db/oct HP??.
So I measure V(out) with and without driver leads attached.
Riddle 1: now I get 2 dB down with this 8 Ohm load (no x/0, naked driver) vs. no load. I calculate output impedance at 2 Ohms, that's bad indeed.
Riddle 2: connecting or disconnecting the woofers on the same side as the mini-Aleph changes the electrical response of the mini Aleph. I get electrical outputs of +1dB at 125 Hz, +2 dB at 100 and at 60 Hz, when I connect the same side woofers, the ones on the same panel as the fullranges driven by the mini Aleph. There is no change if I connect or disconnect the other side's woofers. The bloated midbass output appears when I do connect the same side woofers.
All amps are fed from the same PSU, centrally connected, so it can't be an electrical feedback problem, else the other side woofers would have the same influence. The bloated bass only disappears when the same side woofers are disconnected so it can't be simply high Q resonance whatever.
I can only imagine that the mechanical excitation of the fullrange by the woofers operating on the same panel, creates an EMF and the mini Aleph tries to fight it by raising output. Due to the high Q driver and the high Z(out) of my mini Aleph it doesn't manage though, or even increases the resonance.
Right? Or is there something else? It sounds so outlandish to me.
Back to Riddle 1:
why is the measured output impedance so much higher with a real driver attached, than with a dummy R load? Not just much higher, but very high in the absolute? The IRFP140N should have double the transconductance of the 240's, so a single transistor pair should do as well as 2 pairs in the Aleph 3... or? And the voltage drop is the same if I disconnect everything else from that 375 VA PSU.
I could double up the output devices but I'd rather understand what's happening here first...
Sigh.
Circuit below.
Old 4th August 2003, 12:00 PM   #2
Default circuit
below
Old 4th August 2003, 12:07 PM   #3
setup
Old 4th August 2003, 12:08 PM   #4
Default looks
looks
Old 4th August 2003, 01:27 PM   #5
greyhorse is offline greyhorse  Canada
BMK, R17/18 in your schematic are drawn incorrectly, but is that the way you have your Aleph wired-up? If so, that would explain at least part of your results.
Re-check the schematic here: http://www.diyaudio.com/forums/attac...p?postid=15054
As you can see, R17/18 are supposed to go between the drain of the lower FET and the output. Current to the load is sensed across these, and this signal is fed back to the current source circuit.
If this isn't what's causing your problems, I can't say what it could be.
Old 4th August 2003, 01:39 PM   #6
nobody special is offline nobody special  United States
nobody special's Avatar
Default I could be wrong, but...
I think that Q5 should connect directly to r19, and then r17 and r18 should be in series with the load from that point, with the feedback taken from the load side.
I could be wrong, but the simulator flips out when it is connected as you have it.
If you connect it the normal way, your offset will go up to about 2+ V, and you will need to increase your current through the front end quite a bit to compensate for it.
The bandwidth simulates -3.2db at 80Khz.
Steve
Old 4th August 2003, 01:40 PM   #7
kristijan-k is offline kristijan-k  Croatia
Hello,
Try to rewire you circuit like the circuit diagram below.
You can even use it in balanced configuration with the Balanced
Line Stage preamplifier.
Best regards,
Kristijan Kljucaric
http://web.vip.hr/pcb-design.vip
Old 4th August 2003, 01:43 PM   #8
stefanobilliani is offline stefanobilliani  Italy
Also R10 is a bit low , usually it is 390 ohm.
Old 4th August 2003, 02:04 PM   #9
grataku is offline grataku  United States
MBK,
your 120mV dc offset can be cured by putting a 500ohm trimpot in place of r7 and adjusting the dc offste to 0.
From my experimentation with the circuit the 100pF cap in the feedback loop with a MUCH larger than normal NFB will twist the phase of high frequencies like there is no tomorrow, the amp will likely sound like crap. I also got very funny results playing with the 1nF compensation caps.
I don't know what a AC current gain will do but I imagine it also could cause the dc offset to misbehave and the distortion to raise.
Old 4th August 2003, 02:18 PM   #10
Originally posted by grataku
MBK,
From my experimentation with the circuit the 100pF cap in the feedback loop will twist the phase of high frequencies like there is no tomorrow, the amp will likely sound like crap. I also got very funny results playing with the 1nF compensation caps.
Is this true even with all of his impedances scaled down to where they are? It seems like that cap would be appropriate, considering the 1k to ground, the 20K feedback, etc.
Steve
Aleph Mini riddle makes no sense to me...Hide this!Advertise here!
Boulder's Jeff Nelson makes sense! mikeks Solid State 9 27th November 2011 06:16 PM
whats makes sense to have class A amp? space2000 Solid State 64 7th July 2008 03:46 PM
So, you still not sure if building a GC makes sense? Peter Daniel Chip Amps 65 28th January 2004 11:23 AM
Balanced DAC stage makes no sense to me jwb Digital Source 16 26th March 2002 03:20 AM
Copyright ©1999-2017 diyAudio
