Old 27th March 2011, 09:04 AM   #1
richluvsound's Avatar
Default Pre - Options
Hi All ,
been enjoying my amp while recovering from my hip replacement . I must say, a little bit off morphine mixed with already amazing sound has made the immobility pleasantly tolerable .
I have had the use of a X-2 and have been impressed with the improvement.
I would now like to build a pre , with 2 balanced inputs and an 1 RCA - balanced output .
Please can you give me some ideas of PCB's and possibilities. I separate of PSU
would be a good idea .
This is my second project so KISS please.
TIAA , Rich
Old 27th March 2011, 09:21 AM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
XCCS CCS loaded Jfet BOSOZ
it will work with any possible combination of bal/unbal inputs/outputs
use shunt regs for regs
but - you missed to write which amp is in question
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 27th March 2011, 09:36 AM   #3
Marra is offline Marra  United Kingdom
If you don't need gain I would certainly recommend Sala's DCB1 or a Version of the "Lightspeed". Wishing you a speedy recovery.
Old 27th March 2011, 10:36 AM   #4
Thanks Gents ,
are the PCB's and BOM's for these designs ?
Rich
Old 27th March 2011, 10:43 AM   #5
Wish you a speedy recovery aswell (due politeness before hijacking your thread for a post or two)
Whats the difference between a DCB1 and a stock one? What excactly does it mean to be dc coupled?
Old 27th March 2011, 11:31 AM   #6
Thanks for the good wishes ....
not hijacked , but informed .
I was talking to someone about the B1 ,but from my very limited understanding
I think I would need to build 2 B1 to achieve a balanced version .
Perhaps someone could explain a little for me please ?
Rich
Old 27th March 2011, 12:59 PM   #7
max426 is offline max426  United States
max426's Avatar
something like this
"This is DIY. I view op amps the same way I look at a can of soup or a fast-food burger" NP
Old 27th March 2011, 02:48 PM   #8
Any noticable sonic differences from the balanced?
Old 27th March 2011, 02:56 PM   #9
The DCB1 uses a + & - supply and can be used without input & output capacitors if your source and power amp have them and to boot sounds damn good. I belive Teabag still has boards.
Rich I believe people have built balanced versions of the DCB1 although not so easy with the Lightspeed I understand. I think Maximus has drawn up a schematic for one though.
Old 27th March 2011, 03:11 PM   #10
Say, have you considered ZenMod's Pumpkin? I've purchased a kit, its all you are talking about, balanced, etc., and watching you build one would be a godsend! A little selfish on my part, but this pre is bee's knees from what I hear. (and will drive F-4 if needed)
Russellc
The best tube pre from Vietnam - 818 Pre quanghao Quanghao Audio Design 40 17th January 2012 02:32 AM
MC pre pre amp for shelter 501 MK11 cjcc67 Analogue Source 19 24th May 2010 07:17 PM
Better MC Pre-Pre solution for low internal coil resistance- not only for Pearl phono tiefbassuebertr Pass Labs 5 17th October 2009 10:34 AM
Pre-pre; phono; pre line ;device discrete (bjt/fet) o op. amplifier GIPIONE Solid State 8 18th December 2005 09:09 PM
mic pre opamp options NE5532, LM833, LF353.. any insight? evertestmuse Instruments and Amps 1 23rd February 2004 01:34 PM
Page generated in 0.09925 seconds (77.98% PHP - 22.02% MySQL) with 11 queries
