Comparing power supply of F-5 to F-1
Old 24th March 2011, 08:59 PM   #1
Russellc is offline Russellc  United States
Default Comparing power supply of F-5 to F-1
Looking at the F-1 power supply schematic and noticed it was extremely similar to F-5 with one exception:
The F-5 has a run off of the power supply ground, leading to the CL-60, which then goes to chassis ground.
The F-1 appears identical, except each cap bank has its own CL-60 going to ground, and they are not linked as in the F-5.
Can someone explain why this is, or would either amp work either way? I'm sure there is a simple reason I just am not aware of?
Russellc
Old 24th March 2011, 09:06 PM   #2
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by Russellc View Post
...... I'm sure there is a simple reason I just am not aware of?
exactly
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th March 2011, 12:38 AM   #3
Originally Posted by Zen Mod View Post
exactly
I will stare at it further. Until osmosis sets in!
Russellc
Old 25th March 2011, 12:40 AM   #4
Zen Mod's Avatar
osmozis will tell ya that
in F5 your nose is between two eyes
in F1 there is no nose ...... and eyes are wandering around ......
Old 25th March 2011, 12:46 AM   #5
Zen Mod's Avatar
Default look Ma !
......... there is one channel PSU
Old 25th March 2011, 12:47 AM   #6
Zen Mod's Avatar
Default and ........
there is other channel PSU .........
Old 25th March 2011, 12:52 AM   #7
Zen Mod's Avatar
Default MA! look again !
........ and there is just one channel PSU !
and one leg more , pulling down ........
Old 25th March 2011, 02:17 AM   #8
eyoung is offline eyoung  United States
eyoung's Avatar
Oh I get it 1 Bipolar psu as opposed to 2 polar, on the lower channel if i use F1 psu board flip the polarity of the input from transformer flip my filter caps loose one thermistor tie lower + to upper -??? So i have B+ O B-
Dazed and confused , Elwood
"Lead me not into temptation...I can find it myself."
Old 25th March 2011, 03:00 AM   #9
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The F1 has two supply secondaries, isolated through
thermistors so as to absolutely minimize ground loops.
On a good day they measure about 20 uV unweighted
output noise.
Old 26th March 2011, 02:43 AM   #10
eyoung's Avatar
I probably would have figured it out when I went to tie p/s to F5 boards with their V+, GND, V-...
Or not and melted some three legged fuses.
Regards, Elwood
Comparing power supply of F-5 to F-1Hide this!Advertise here!
Comparing Power BJTs (Sanken, ON Semi, ...) panson_hk Solid State 15 29th November 2012 01:24 AM
Hagerman Bugle power-supply or for +/-15dc 100ma generic supply. tweakk Swap Meet 3 23rd February 2011 06:46 PM
Comparing Bose(o) Chip Amps 5 29th July 2005 09:19 PM
Comparing sensitivities Grahamt Multi-Way 2 20th September 2004 06:42 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Copyright ©1999-2017 diyAudio
