Initial setting of F5 bias--help, please! - Page 3 - diyAudio
Old 23rd November 2012, 10:37 AM   #21
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
PM sent, thanks!
Old 22nd June 2014, 04:14 AM   #22
kkerwin is offline kkerwin  United States
hi
i am in the process of firing up (probably not a good choice of words) my new f5. i have successfully biased one channel and am having difficulty on the second channel.
with both p1 and p2 turned fully counterclockwise, they each measure 0 ohms resistance. when i power up the channel, r7 reads around 190mv while r8 is at 0mv. turning p1 does not affect the voltage across r7, and p2 cannot be adjusted to result in more than about 30mv across r8. i have double/'triple checked the resistor values and they all seem ok. is it possible one of the transistors is bad?? any suggestions for troubleshooting this problem?
thanks
k
Old 22nd June 2014, 08:36 AM   #23
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
recheck all solder joints
recheck trimpot
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 22nd June 2014, 08:59 AM   #24
Kk,
as you adjust the trim/bias pot from zero ohms you can measure the voltage across it.
That voltage across the VR is the output device bias voltage.
Measure and see if the P1 change in voltage roughly matches the P2 change in voltage.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd June 2014, 10:56 AM   #25
KatieandDad's Avatar
Might seem daft but check that you have the correct MOS-FETs in the correct positions.
Old 23rd June 2014, 03:15 AM   #26
found that r7 and r8 were damaged. i may have done this on hook-up. when i first connected that channel, i had the power on and connected the negative and positive a few seconds apart. the rest of the circuit seems to check ok. i have a couple of .47r resistors on order. the other channel is working very well.
thanks
k
Old 23rd June 2014, 10:17 AM   #27
ALWAYS use the bulb tester to power up a mains powered project after EVERY modification.
There is no excuse for damaging new equipment due to laziness.
regards Andrew T.
Old 23rd June 2014, 11:43 AM   #28
hi andrew,
less about lazy, more about inexperience. how do you use the bulb tester?
thx
k
Old 23rd June 2014, 12:35 PM   #29
plug your equipment into the bulb tester.
plug the bulb tester into the mains socket.
switch ON.
Does the bulb flash briefly, or a prolonged dim down, or glow bright?
regards Andrew T.
Old 23rd June 2014, 01:03 PM   #30
thanks andrew,
i will check this out.
k
P3A bias setting werfi Solid State 15 8th February 2010 07:03 AM
P3A bias setting werfi Solid State 0 31st January 2010 07:11 PM
Setting Bias kptseng Solid State 9 8th March 2008 01:56 AM
bias setting ben goh Solid State 8 14th August 2006 04:26 PM
Problems with bias setting Cicero Solid State 5 21st January 2005 08:01 AM
Copyright ©1999-2017 diyAudio
