I'm in the middle of building my F5 and my thoughts are turning to grounding. For my stereo F5 I've built a separate power supply for each channel. This means that each channel has its own toroid, rectifiers, and capacitors. Can I ground each power supply to its own CL60 on the chassis or am I best to stick with the well known start grounding principle and bring both power supplies to a common CL60? The reason I'm asking is separate CL60's would probably lead to a neater layout.
Regards, Dan |
#2 |
The point of the CL-60 at chassis earth is to break ground loops.
Star ground the 2 PSU boards to one CL-60.
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
#3 |
I built an F5 with CL-60s for each power supply. It's very quite.
I build, therefore I am. |
#4 | |
What about the CL-60 that goes to ground, did you use one for each side, or just one for both grounds? If you used two, (One for each power supply) did they both go to the same ground point, or did each have their own ground point? Russellc |
#5 |
I used two, one CL-60 for each power supply (PS) ground. My logic was that if they shared a single CL-60, both PS circuits would be connected to ground before the CL-60.
You are correct. The pics shows thermistors before the transformers. There are 6 CL-60 total in that F5. Vince
I build, therefore I am. Last edited by vdi_nenna; 15th March 2011 at 05:47 PM. Reason: grammar |
#6 | |
Thanks for the help here, much appreciated. Russellc |
#7 |
safety gnd ( routed from mains connector ) , and all NTC's ( usually one or two ) connecting audio ground(s) and safety gnd , must be bolted/connected to one point of case
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#8 |
#9 |
Both cl-60s to one point, bolted to the bare chassis, like ZM said.
#10 |
Look at F1 P/S has 2 CL60 to ground on the +/- 24v both channels to Ground...
Regards, El
"when you open your mind to the imposible, soon you will find the truth...." |
| F5 Amps - Building a Quartet of Amps in search of the Ultimate F5 | NYCOne | Pass Labs | 123 | 29th September 2011 12:04 AM |
| F5 Cascoded - an alternative for my interest in the Balanced F5 | NYCOne | Pass Labs | 159 | 24th March 2011 05:23 AM |
| I need Help with my F5.... | rtate | Pass Labs | 15 | 1st December 2009 11:07 PM |
| Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... | EchoWars | Solid State | 37 | 3rd August 2008 08:50 AM |
| LM3875 kit grounding, optimal grounding for separate amps and psu? | findog | Chip Amps | 9 | 16th May 2005 09:27 PM |
| Page generated in 0.09980 seconds (79.35% PHP - 20.65% MySQL) with 11 queries |
