I want to know if exist a GB for pcb to make the Aleph J-X 50W, also I need: schematic, psu & transformer (voltage & power) & proper heatsink.
#2 |
Peter Daniel sells PCBs for Aleph J-X. You need to buy two Aleph J boards per channel and Peter supplies the daughter board as well to connect them up to make a X of that.
Check GB of Peter or email him.
F5 clone, Aleph J clone, Fostex 206 BLH, Altec/Onken, Behringer Digital Xover, Technics SP10 MKII & SL-1210. |
#3 |
Yes I asked there & told me 100W
#4 |
With those boards you can get any suitable power output, just adjust voltage rails accordingly.
Low watt Aleph J Balanced F5 question
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#5 |
The Aleph-X and it's variants like the Aleph-JX are something for the more adventurous as it usually requires more experience in building amps. The AX was not published by Nelson, it was originally a prototype developed by Grey and does not have the perfect level of maturity like amps build in series production (or the ones published by Nelson).
If you're not sure how to downscale the 100W amp, you might be better off building something better documented (AlephJ, F5). Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#6 |
@Peter Daniel
@h_a Thanks for the info. |
| 50W amplifier | seacucumber | Class D | 1 | 10th February 2010 08:38 PM |
| 50W amp | zeus_threat | Solid State | 64 | 5th September 2007 08:27 AM |
| Aleph-2 50W@8ohm 20KHz | emb51 | Pass Labs | 8 | 8th September 2006 04:10 PM |
| FS: 50W Aleph-X parts set including chassis | tiroth | Swap Meet | 6 | 19th December 2004 02:34 PM |
| Page generated in 0.07208 seconds (76.49% PHP - 23.51% MySQL) with 10 queries |
