2SJ109 in Aleph J:  Is Vgrade ok?
Old 1st March 2011, 04:46 AM   #1
krivium is offline krivium  France
Default 2SJ109 in Aleph J: Is Vgrade ok?
Hi to all.
I may have a possibility to source some 2SJ109 (but few of them...not more than 2/4) V grade.
From some search on the forum i found that for the Aleph J (i plan to buid) preferably they must be BL type, GR won't work but not so much info about the V type.
I would say it should be ok but could you confirm me this and eventually modification from the original schematic from Mr PASS in case it's needed?
Many thanks to you.
Krivium.
Old 1st March 2011, 08:05 AM   #2
h_a is offline h_a  Europe
h_a's Avatar
the AlephJ biases the frontend with the aid of a constant current source at 8.3 mA; so regardless of grade anything works that has an IDSS of above 4.15 mA (the 8.3 mA is split between the 2x jfets in the package).
You can use it (without modifications), however, there might be better chances to use the V.
Hannes
High Octane phono preamp Wiki
Old 1st March 2011, 11:24 AM   #3
Bill Fuss is offline Bill Fuss  United States
RIP
Don't you think you would need a little room on the Idss for signal swing? If you run out the front end will clip. I generally use an Idss as high as the total front end current, which can be adjusted to match the Idss of the jfets you are using.
Old 2nd March 2011, 01:06 AM   #4
Hannes thanks for the answer.
Bill could you explain more? EG for the 2SJ109V in Aleph J it would be a modification of R8 from 1k to 500r for example?
2SJ109 in Aleph J:  Is Vgrade ok?Hide this!Advertise here!
2SJ109 Bksabath Swap Meet 32 5th October 2010 03:42 PM
Heatsink at 2SJ109 in Aleph J frags Pass Labs 9 11th September 2010 07:02 PM
Aleph-X with 2SJ109 as input pair h_a Pass Labs 51 15th June 2007 09:47 PM
Exchange: 2sj109 V for 2sj109 BL genome Swap Meet 0 23rd November 2005 12:36 PM
WTB: 2sj109-V or 2sj109-BL rtirion Swap Meet 0 18th August 2005 02:13 PM
Copyright ©1999-2017 diyAudio
