Old 30th July 2003, 03:31 PM   #1
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Question BOSOZ PS Question
The original project calls for one power supply board for both channels. Has anyone used 2 PS for the project?
Or, are 2 PS boards not nessecary?
Thanks,
Vince
Old 30th July 2003, 04:40 PM   #2
nobody special's Avatar
I haven't built one personally yet, but when I do I will use two regulator boards, if not two seperate transformers- one for each channel. It's just a way to get better channel seperation- a "dual mono" approach.
Nobody
Old 30th July 2003, 05:25 PM   #3
The one and only
Nelson Pass's Avatar
As long as the single supply has adequate current, there
is no reason you can't use it.
Old 30th July 2003, 06:29 PM   #4
As an experience with BOZ preamplifier , an extra filtering portion in the original circuit is a nice thing , and it produce good results . I find it here http://apu.freeshell.org/pre.html at the mid bottom of the page click to enlarge the PSU image.It is an experience with BOSOZ from an Italian guy.
Old 3rd August 2003, 09:49 AM   #5
Roberto Amato's Avatar
I used two PSU with much larger condenser banks. The difference I found between the single PSU and a double one is a slightly better imaging and detail in favor of the double PSU. The single one, anyway, was adequate to drive both channels.
ciao,
Roberto Amato
Old 4th August 2003, 10:25 PM   #6
lgreen is offline lgreen  United States
lgreen's Avatar
Default only 1 needed
To answer your question, you only need a single power supply board, it provides sufficient power to drive both channels. However, you will find that people around here make two boards to go dual mono. I have also done this but it certainly is not necessary. You could also increase the capacitance or make other modifications to suit the result you want.
BoSoZ PSU Question Raoul Pass Labs 4 8th March 2005 02:44 PM
bosoz question... cowanrg Pass Labs 9 27th November 2004 01:39 AM
BOSOZ with CCS, and a question jh6you Pass Labs 11 26th March 2004 05:25 AM
Bosoz psu question protos Pass Labs 8 25th November 2002 03:39 PM
BOSOZ question audionut Pass Labs 1 27th July 2002 02:34 PM
Page generated in 0.07889 seconds (73.28% PHP - 26.72% MySQL) with 10 queries
