25W Class A amp with Lateral MOSFETs
Old 14th March 2016, 10:06 PM   #121
acamilicko is offline acamilicko  Serbia
acamilicko's Avatar
Originally Posted by Guitar.mod View Post
Nice Work!
p.s. Little note: gate stopper resistors should be as near to the gate as possible.
In Your version - these are as far as possible
Also low power signal "GND" shares same trace as power "GND", this practice should be avoided. It should go with separate traces to star gnd poi1nt.
I agree. This PCB was designed some year ago, and in speed. Though, I made amp with that PCBs and.. In a very serious system, with serious source, serious speakers and sound absorbers and diffusers - this amp shined like a true star... So I decided not to make new modified PCBs
In a link I provided you can download Eagle PCB files and everyone is free to modify PCB as long as they want...
No, there is no BUMP (as Juma said, obviously), there is just some wait time for output cap to fill with electricity before the pop-rock starts.
If you gonna make this amp, although it work very fine with bias of 500mA, I recommend making it as specified, with 1A3 bias - it will shine even more...
Keep it simple!
Old 14th March 2016, 10:54 PM   #122
Jay is offline Jay  Indonesia
Banned
Also low power signal "GND" shares same trace as power "GND", this practice should be avoided. It should go with separate traces to star gnd point.
This is actually better implemented than most amplifiers here It is hard to achieve good result without understanding the issues and how to avoid them. Many people just follow the "golden rules of thumb" and still the result is not good. As an example, sometimes "star grounding" is used only to make things worse.
Besides, this is single ended with CM regulation.
Old 15th March 2016, 07:18 AM   #123
Guitar.mod is offline Guitar.mod  Lithuania
Originally Posted by juma View Post
I thought it was obvious that there is no turn on/off thump.
Dear Juma and Acamilicko, thank You! When I made some years ago LM1875 (single supply with output cap version) - there was very huge and slow, harmful bump.
I think that bias 400-500mA should be enough. Also I am thinking about F5 with BJT input simple version similar to "TSSA". It's advantage - Output with gain - we have more headroom with same power supply voltage, less wasted power.
Old 21st August 2016, 05:53 PM   #124
ernesternest is offline ernesternest  Europe
ernesternest's Avatar
Default miniversion
Yeah! Totally agree
Such a quality amplifier, amaizing.. Totally forgotten without reason. So simple construction, and so precise sounding amplifier, a lot of details and in the same time pretty transparent - CLASSY AMP!
I've built "mini" variant starting with 200mA bias, and ending up with 500mA - good for these heatsinks. With half of ampere bias it sounds a lot better than low bias, and as Juma says, it shouldn't be less to achieve good sound.
Slim pcb version>
Eagle pcb files> http://www.diyaudio.rs/index.php?app...ttach_id=38642
More images and process of work here: Projekat: SVAJA - Stranica 6 - Solid State - diyAudio.rs
Thanks Juma!
Aleksandar,
I wonder, if the only "change" for your miniversion is the reduced current?
cheers Ernst
Old 21st August 2016, 07:44 PM   #125
pchw is offline pchw  United States
Can someone attach the pdf and the Eagle files here?
Thanks!!
- Fred -
Old 19th June 2017, 12:48 PM   #126
Skorpio is offline Skorpio  Denmark
Could this amp be easily "upgraded" with positive feedback, as the F7?
Old 19th June 2017, 05:39 PM   #127
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I think so. It's pretty easy to do, just check Lhquam's posts with formulas
for most (or all) the variations you might want.
Old 20th June 2017, 07:01 AM   #128
juma is offline juma  Germany
juma's Avatar
It's very different from pre-PF F7 (which is basically slightly modified old Zenotron amp) so it won't necessarily be an upgrade, but it will bring a change in performance for sure.
You'll get more distortion an somewhat higher damping factor, depending on how much positive feedback you use. You won't know how it sounds before you build it and be prepared to experiment with PF until you find what you like.
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 20th June 2017, 07:16 AM   #129
stoolpigeon is offline stoolpigeon  Australia
stoolpigeon's Avatar
Hi juma
Since you've mentioned the zenotron can I ask what you think of it?
I've always had in mind to build one of your designs but never had quite the right parts or level of skill (since I will be hard wiring it) but I have everything for the zenotron.
Plus my old ears ain't what they used to be.
Thanks, sp
Old 20th June 2017, 08:30 AM   #130
juma's Avatar
Zenotron is OK but it can be easily improved without added complexity - see this:
http://www.diyaudio.com/forums/pass-...s-latfets.html
or, even better, this:
Cubie2
Threads are not very long, read them and see if something fits the bill...
25W Class A amp with Lateral MOSFETsHide this!Advertise here!
Ode to Lateral MOSFETs Lumba Ogir Solid State 67 3rd September 2017 07:09 PM
X-Amp (LME49830 + Exicon Lateral Mosfets) danfo098 Chip Amps 28 14th October 2013 04:05 AM
Substitute Lateral Mosfets joensd Parts 33 21st December 2008 01:57 PM
Lateral mosfets - why ? Stormo Solid State 5 2nd July 2003 07:14 AM
Copyright ©1999-2017 diyAudio
