F5X -- the EUVL Approach - Page 82 - diyAudio
Old 5th April 2013, 02:12 AM   #811
EUVL is offline EUVL  Europe
One more comment I want to make about how to compensate for the difference between K170/J74 Yfs.
In my first build, I calculated the combined open loop gain of the first & second stages of the top & bottom halves respectively and balanced them by adjusting the value of the MOSFET source resistor as well as the feedback resistor network values.
I have in the public version changed that approach, not only because it is more complex to calculate and understand, but also for philosophical reason. The current design philosophy is that any "error" should be corrected for locally where they occur. And since the 2SK1530/2SJ201s are perfect complementaries, the correction is only done at the front end, namely the 5R extra degen for the 2SJ74s.
The same approach is used for the F5XP, for example. In this case, the first stage also has the 5R degen for the 2SJ74. So the gain of the first stage is balanced. The second stage also has an imbalance between the 2SK216 and 2SJ7 both in Yfs and in Vgs, and this is then compensated by adjusting the source resistor values.
The advantage of this more laborious approach is that if one day we find a perfect complementary pair of TO220 devices, we can take out the Renesas laterals and subsititute these in, but then with equal source resistor values.
i.e. if each stage is individually balanced, you can change one without affecting the other.
As said, it is a philosophical thing. There is no proof if one sounds better than another.
What I said in post #1 ?
100 ways t skin a cat.
Patrick
xen-audio.com
Old 14th May 2013, 12:49 PM   #812
ramallo is offline ramallo  Europe
ramallo's Avatar
Send a message via Skype™ to ramallo
Today I powered up one of my amp modules
330mV after 2:30 hours, -20V/+19,98 supply
190mV offset on negative side 90mV on positive (to ground)
need I to do an adjustment like the regular F5 for get the lowest offset on each side?
Happiness is a warm soldering iron
Old 14th May 2013, 02:25 PM   #813
Measured after CRC ?
Sounds high; what is the bias current ?
Yes.
But perhaps better to post at the build thread and continue from there ....
F5X -- the EUVL Approach - The Build Thread
Patrick
xen-audio.com
Old 15th September 2013, 09:09 PM   #814
Originally Posted by EUVL View Post
As promised.
Patrick
From the diagram attached to post #706.
I see VE + and - for left speaker are connected to the same pole?
Old 17th September 2013, 12:02 AM   #815
I do not quite understand the question.
I checked the diagram and cannot spot any mistake around the left speaker.
The only thing is that Mark (who drew the schematics) was using 12V relays, so he wired the left & right protection relays in series.
Maybe you can explain further ?
Patrick
xen-audio.com
Old 17th September 2013, 02:24 AM   #816
Thanks Patrick,
Attached is my query, Iíve highlighted the connection from the left speaker that runs back to left channel + and - amp board from only ONE speaker pole.
File Type: jpg Screen shot 2013-09-17 at 12.17.33 PM.jpg (77.5 KB, 361 views)
Old 17th September 2013, 05:04 AM   #817
No John.
Close the relay contact on the left and draw the line from Amp VE+ in red.
Patrick
xen-audio.com
Old 17th September 2013, 06:11 AM   #818
Thanks Patrick, of course, makes much more sense now, I couldn’t see it for the life of me.
Old 28th September 2013, 01:42 AM   #819
alazira is offline alazira  United States
alazira's Avatar
If I may ask, why place the relay on the +positive side?
Old 28th September 2013, 05:46 AM   #820
Why not ?
Any side will do. You can also use DPDT.
Patrick
xen-audio.com
Copyright ©1999-2017 diyAudio
