F5X -- the EUVL Approach
Old 8th February 2012, 05:45 PM   #681
EUVL is offline EUVL  Europe
> I second that! You can put me on the GB list now.
I thought you wanted a F5X Preamp first ?
Patrick
xen-audio.com
Old 8th February 2012, 05:50 PM   #682
Horio is offline Horio  United States
Horio's Avatar
Yea...That too!
Old 8th February 2012, 05:55 PM   #683
One at a time. First finish the F5X.
Patrick
xen-audio.com
Old 8th February 2012, 06:23 PM   #684
A discussion about output device choice can be found here :
F5 Turbo is posted
Further details published :
F5 Turbo is posted
Patrick
xen-audio.com
Old 12th February 2012, 03:57 PM   #685
There are some discussions about the level of Vgs match between P type & N type output devices at the GB thread :
http://www.diyaudio.com/forums/group...ml#post2903207
While the discussion over there is whether the supplier has delivered what he promised, most of you would be interested in how well the P-N matching has to be. After all, perfectly P-N match is an absolutely rarity.
http://www.diyaudio.com/forums/group...ml#post2903371
The consequence of a slight mismatch between P & N devices is an increase in second harmonics. While this is more important for the single ended F5 ( and hence Nelson's modified version to include a trimpot across the two feedback shunt resistors), it is much less important for the F5X, as even harmonics will cancel out between the left and the right halves, provided they behaves identically. And the latter can be achieved through good N-N and P-P match, which is much easier to obtain. I consider a 20dB cancellation between left & right halves to be achievable.
Further fine tuning of the even harmonic contents of each (L or R) half is still possible, either by trimming the feedback shunt resistor, as Nelson proposed, or by trimming the output MOSFET source resistor, as he did earlier with his First Watt F5's using Fairchild devices. Note than the Fairchild devices has no P-N match at all. The Vgs at 1.3A (for single ended F5) differs by more than 1V !!
All these issue would be dealt with once fitzfish finds time to start the Build thread.
Right now he does not have enough time to sleep.
One should not forget that this is hobby, and we all have a living to make in the first place.
Patrick
xen-audio.com
Old 12th February 2012, 04:03 PM   #686
For more info on P-N match we published in 2008, see :
F5 power amplifier
followed by the same info for Fairchild MOSFETs as used by Nelson :
F5 power amplifier
Patrick
xen-audio.com
Old 12th February 2012, 06:32 PM   #687
CanAm Man is offline CanAm Man  United States
F5 power amplifier
F5 power amplifier
Patrick
Patrick.... I appreciate you taking the time to "dig out" the relevant info, and for posting the links. It really helps us who are still attempting to come up to speed on F5 and F5X topologies. These "mega-threads" have a wealth of good info in them--digging them out can be a real chore, so my thanks for doing that legwork. I know you're busy--I appreciate you taking the time.
Old 12th February 2012, 06:57 PM   #688
Patrick
xen-audio.com
Old 26th February 2012, 04:56 PM   #689
lhquam is offline lhquam  United States
EUVL:
Is there any consensus about the X topology vs. balanced as shown in Nelson's F5 Turbo Balanced Template? How would one introduce the P3 adjustment into the X?
Old 26th February 2012, 05:07 PM   #690
There is no consensus. This is how I would build a balanced F5.
As said in post#1, only one of the many ways to skin a cat.
And as already mentioned, in simulations and measurements, the floating and grounded X behave similarly.
But the floating X is capable of taking single ended input. The grounded X needs balanced input signals.
With proper matching between left and right halves, all even harmonics will cancel out in the F5X.
There is no need to introduce the P3 adjustment. In particular not with Toshiba Mosfets.
Patrick
xen-audio.com
F5X -- the EUVL ApproachHide this!Advertise here!
