F5X -- the EUVL Approach - Page 65 - diyAudio
Old 9th January 2012, 04:15 AM   #641
EUVL is offline EUVL  Europe
Yes.
Patrick
xen-audio.com
Old 9th January 2012, 04:24 AM   #642
hi apex send me calculation of transformer using EI core and toroidal core. thanks! send it to iiee3602@yahoo.com
Old 9th January 2012, 05:13 AM   #643
qusp is offline qusp  Australia
qusp's Avatar
i think you posted in the wrong thread iiee3602
Old 11th January 2012, 06:04 AM   #644
I have a question about the BOM:
Is the Idss of the JFET specified at 10V 25C ?
Thanks,
Davide
Old 11th January 2012, 06:18 AM   #645
Depends.
In the standard version, the FET will see about 13V at Idss.
So if you want to be exact, this would be the working condition you need to match at.
(For the P-JFET with 5R degen.)
But room temperature match at 10V is close enough for most.
Patrick
xen-audio.com
Old 22nd January 2012, 01:26 AM   #646
Happy New Year to our Chinese and Hong Kong members.
Davide
Old 22nd January 2012, 04:51 AM   #647
Davide,
Many thanks on behalf of them, but you are actually one day too early.
Chinese New Years day should be 23 Jan 2012.
But Mark & Co are already not reachable by email till end of January.
Here also picture of a Chinese Dragon, which is a bit different from its European counterpart.
Patrick
xen-audio.com
Old 22nd January 2012, 04:54 AM   #648
For the case subscribers, the cases were actually all packed ready to ship by Thursday.
But the bank transfer from John had not arrived.
So we all agreed that they would be shipped when Mark comes back, which will be 2 Feb.
Patrick
xen-audio.com
Old 26th January 2012, 02:15 PM   #649
EUVL,
Can you point me to the documentation related to F5 bridging.
I am trying to understand if I can use it in my situation.
forgive my ignorance. I see that in the balanced version, we can make it work like bridged amp. Is that true.
If my preamp has output of 3v rms, and has rca outputs, can it be used.
pandu
Old 26th January 2012, 02:23 PM   #650
The F5X as described in this thread, in the floating X configuration, is straightly speaking a fully differential amplifier as opposed to a bridged amp using 2x single ended amps. The grounded X configuration, however, can be considered as a bridge amp.
Again in theory you can use the floated X configuration with RCA inputs. But for optimum performance, we strongly recommend fully balanced inputs.
RCA inputs however will not work with the Grounded X configuration. You need to use a single ended to balanced converter, such as e.g. a Phase Splitter.
Eventually when fitzfish is ready to start his build & test thread, the issue for using RCA inputs as well as the performance under these conditions would be described in detail.
Patrick
xen-audio.com
Copyright 1999-2017 diyAudio
