F5X -- the EUVL Approach
Old 9th December 2011, 11:46 PM   #601
smyslow is offline smyslow  Europe
Impressive results Dave! And also impressive lab equipment.
Attached a picture from my "kitchen table" and an additional scope plot. For this I've used my UGS-based preamp as a single to differential converter to get a balanced input voltage. The cheap USB-scope with build-in waveform generator doesn't give such a voltage. Now the results are much better than the former one, even without the cascode devices.
Uwe
Old 9th December 2011, 11:52 PM   #602
EUVL is offline EUVL  Europe
All great results. Congratulations.
Patrick
xen-audio.com
Old 9th December 2011, 11:59 PM   #603
BTW there is a third member of the test team who has been giving me very detailed reports of his tests and many valuable suggestions and feedbacks.
I also thank him sincerely for all his hard work, but leave him to decide whether he wants to post his results.
Patrick
xen-audio.com
Old 10th December 2011, 04:41 AM   #604
fitzfish is offline fitzfish  United States
Hi Uwe,
Thank you, yours too! Making a DIY test and measurement setup like yours work well is much more interesting than what I am using. I enjoy making tools and fixtures as much as the projects themselves...
Dave
Old 10th December 2011, 06:51 PM   #605
Those who might like a very simple phase splitter to convert single ended signal to balanced might want to have a look at this :
Fet based phase splitter?
Don't use this to supply the F5 for THD measurements.
Patrick
xen-audio.com
Old 11th December 2011, 09:44 AM   #606
ashaw is offline ashaw  Australia
So I am in the middle of testing the protection board. All seems to be going well so far. Current measurements:
The power supply ripple is 20mV on the +/- 12V rails and 8mV on the 5V rail.
Every part of the circuit that I have tested so far works.
Supply voltages are OK accurate (set by 7800 regs).
Old 11th December 2011, 09:57 AM   #607
Are we then ready to release the protection board after you send us the revision ?
Patrick
xen-audio.com
Old 11th December 2011, 10:02 AM   #608
Not quite yet, will finish testing tomorrow. However I cannot see anything going wrong there.
A general question: what would people prefer for connectors on this board?
No connector, just 0.8mm holes;
4 pin JST connectors;
The MOLEX 2mm connectors that are on the current board.
None of these will hold up the release of these boards.
Old 11th December 2011, 10:34 AM   #609
johnwmclean is offline johnwmclean  Australia
Molex 2mm connectors work for me.
Old 12th December 2011, 11:04 PM   #610
alazira is offline alazira  United States
alazira's Avatar
I'd prefer 0.8mm holes.
F5X -- the EUVL ApproachHide this!Advertise here!
