F5X -- the EUVL Approach - Page 54 - diyAudio
Old 14th October 2011, 01:22 AM   #531
buzzforb's Avatar
Vertical line on right side.
Old 14th October 2011, 01:23 AM   #532
vertical line on the right of panel ?
Old 14th October 2011, 01:35 AM   #533
EUVL is offline EUVL  Europe
Well spotted.
But both missed a second line on the left.
It is only visible at a certain angle, and hence not on all photos.
But it is visible.
Patrick
Old 14th October 2011, 01:59 AM   #534
EUVL,
I had noticed it before, but thought it might just have been the image.
Any possibility it's an artifact from the milling process?
Old 14th October 2011, 02:13 AM   #535
We have not seen this from milling before.
Still to be investigated.
Patrick
Old 15th October 2011, 03:06 PM   #536
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by EUVL View Post
We are going to take you through the assembly, starting from the finished product, and removing parts to review the inside, one by one.
Starting with the overall views.
Only the few screws on the top are visible, and nothing protruding above the metal surface.
This is only possible when the machining tolerances are tight enough.
Patrick
Outstanding ! Really !
Must discuss prices sometime
RC
Old 15th October 2011, 03:40 PM   #537
qusp is offline qusp  Australia
qusp's Avatar
could it be some sort of seam in the raw material?
Old 15th October 2011, 04:03 PM   #538
NicMac is offline NicMac  Italy
NicMac's Avatar
Patrick,
How thick is the front panel? It looks like 2-3 cm.
I imagine the control PCB will be mounted flush on the inside. Will the components be facing outwards (i.e. embedded in the machined groove)?
Nic
Old 15th October 2011, 04:09 PM   #539
The components are inside the pocket on the rear side of the front panel, which is 15mm thick.
Patrick
Old 15th October 2011, 04:16 PM   #540
NicMac's Avatar
Amazing! I have never seen anything like that before.
Copyright 1999-2017 diyAudio
