Is the F4 the most-suitable FW amp for me?
Old 16th February 2011, 05:54 PM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by jeffreybehr View Post
I guess I'll control my infatuation with the F4
naah
not funny enough
it's funnier to build them and listen , than just to buy them and listen
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th February 2011, 05:59 PM   #12
ra7 is offline ra7  United States
Originally Posted by Melon Head View Post
The F4 will sound different depending on what it is driven by, and since a cd player does not have enough voltage to drive the F4 to decent power levels most people will be a putting some sought of high gain preamp or power amp in front of it which will heavily influence the sound coming out of the speakers.
I've always been confused by this... how do you drive an F4 with a power amp? Its in the manual, but never understood how it would work. First of all, how do you connect a power amp to the F4 input?
Old 16th February 2011, 06:03 PM   #13
Melon Head is offline Melon Head  Australia
Banned
You will have to add rca connectors at the output of the amp to hook up to the F4.
Or use your imagination to come up with many other ideas to connect a power amp to the F4
Old 16th February 2011, 06:11 PM   #14
Zen Mod's Avatar
just put 8R dummy load at output of your amp , solder some cable to same , solder RCA to end of cable and plug it in F4
then F4 is current buffer for your flea power amp ( as Papa calls it )
pictures at 6moon F4 presentation
you can use lighter dummy load ( more ohms ) if your tiny power amp is happy with it
Old 16th February 2011, 06:38 PM   #15
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
More often than not you will want to use a dummy load
of a higher impedance, say 16 ohms, and be prepared
to adjust it for different sound.
Old 16th February 2011, 06:43 PM   #16
Cool... thanks all! I have some F4 PCBs... someday....
Old 16th February 2011, 10:27 PM   #17
jeffreybehr is offline jeffreybehr  United States
Nelson, any comments on the suitability of F4s for my application?
Also, are Cs1 and 2 signal-coupling caps? If so, what is the resistance they're driving? My app requires the amps to have the MR-high-pass filter in them.
Old 17th February 2011, 07:08 PM   #18
Nelson?
Old 20th February 2011, 04:36 PM   #19
Nelson?
Mr. Pass? Comments on my original and subsequent questions?
Old 20th February 2011, 05:19 PM   #20
flg is offline flg  United States
flg's Avatar
I'm not able to answer your question but I would like to suggest the possible influence on the sound that may be expected. The F4, using no feedback is subject to some coloration. I beleive ordinarily you would expect mostly 3rd harmonic coloration from this type of circuit. And, although small, it will add a particular sound. Due to the use of IRFP9240s, some 2nd harmonic will predominate, possibly giving it a warmer "tubey" sound. You can read about this phenomina in the BA-2 article in the performance section as the F4 is a very similar output stage. The F5 however does use feedback. And, although it also uses IRFP9240s the gain/feedback topology of the circuit is likely ruducing the 2nd harmonic and distortion overall giving a slightly different sound.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Is the F4 the most-suitable FW amp for me?Hide this!Advertise here!
FS : ELNA forAUDIO & Nichicon FW Caps Pocoyo Swap Meet 9 12th October 2011 12:31 AM
Suitable woof & tweet for CV Full Range chip amp? lunchmoney Chip Amps 3 20th March 2011 06:00 PM
Consent for work on your FW suds Pass Labs 24 15th June 2009 02:55 PM
ecl86 & ez80 - suitable for guitar amp? greenstax Instruments and Amps 20 22nd August 2007 10:10 AM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 08:49 PM
