I have read as many threads as possible about the volume selector for the Balanced Line stage. Unfortunately nobody can dictate a balanced 4gang 5K pot for a reasonable price. I beleive that once building such a preamplifier you must buy a good pot. I beleive that the Dact Ct2 fits the price nicely but the problem is that it is 10K. Is this a problem? Can I bypass this problem and how? Also take into account that we in Europe do not have the ability to easily shop from US shops due to customs and courrier costs involved. The dact can easily be baught in Europe.
If anyone can give an alternative solution I would be more than pleased. Thanks George |
#2 |
Why don't you take a look at Elma stepped attenuators?
Borbely would be a great start. Nick |
#3 | |
Banned
http://www.passlabs.com/pdf/aleph/apserv10.pdf |
#4 |
Nickolas thank you, I will check Borbelies Elma attenuators. The relais solution is a bit complex for me.
Thank you for your replies |
#5 |
Nickolas,
I only found the Elam series N audio switches to be ready made with resistors already soldered on the attenuator, but this pot is for 10K or bigger resistance!!! It is not available for 5K resistance. I will keep on looking. |
#6 |
Nickolas,
In the past you were taking about the BI Tech. 6670 pot. Where can I buy it in Greece? The dealer Micronics Ltd does not have it. Thans |
#7 |
Account Disabled
This could be one solution among others.
Use the input P1 and P2 of 10K as a volume. Remove the output P3 and P4, or use a simple output voltage devider (of Ra + Rb = 5K).
#8 |
why not buy a goldpt stepped attenuator kit and solder in your own resistor values?
there are several websites that compute those values for you |
#9 |
I just received an email from Goldpoint. They will assemble a "custom" 5K pot for no additional charge.
| Wtb / Wtt: Dact Ct2 10k | cartman | Swap Meet | 0 | 14th June 2008 08:19 AM |
| Fs: Dact Ct2 | PHilgeman | Swap Meet | 2 | 29th May 2006 06:51 PM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Page generated in 0.08633 seconds (75.55% PHP - 24.45% MySQL) with 10 queries |
