Aleph 30 input connections ? - diyAudio
Old 13th February 2011, 10:59 AM   #1
matsj is offline matsj  Sweden
Send a message via MSN to matsj
Default Aleph 30 input connections ?
I have 2 aleph 30 pcb laying on my board and i have lost my papers on them. Can someone help me with the input connections ?
I have a bad pictures if that can help.
From left: gnd, sg, in+, in-. In the in- there is a small wire to the right unmarked hole.
Is In+ to pin 2 on xlr ?
Is SG to pin 1 ?
Is gnd to pin 3 ?
mats
Horns forever
Old 13th February 2011, 11:04 AM   #2
anilva is offline anilva  India
Is SG to pin 1 ?
Is gnd to pin 3 ?
mats
Pin 2 on XLR is +in and 1 is Signal Ground (SG).
As far as I can see in the picture, the -In is taken to ground to make the amp a single ended amp instead of a balanced input. Will work fine.
Cheers.
DIY F5, F5T, F6, Aleph J, Fostex 206 based BLH, Altec Onken with 515 LF & 288 HF, Technics SP10 MKII & EMT950 turntables
Old 13th February 2011, 11:33 AM   #3
Thank you for answer. How do i do for working on both balanced and single end input ?
mats
Horns forever
Old 13th February 2011, 01:40 PM   #4
RIP
Leave the shorting jumper off of the board and make a shorting jumper to plug into the XLR that connects pin 1 and 3 when you are using the RCA inputs. Pass Labs supplies these with the amps they sell.
pin 1 is SG, pin 2 is in+, pin 3 is in-
Old 14th February 2011, 11:02 AM   #5
Thank you very much. IŽll change the cables and use shorting jumpers in the xlr plugs.
mats
Horns forever
ZVP3310 - Good choice as input fet for Aleph 30 hifinerd Pass Labs 27 18th April 2015 11:09 PM
F/S mini Aleph/Aleph 30 pcb Assesears Swap Meet 5 30th March 2008 08:29 PM
Question on Input Connections dsavitsk Tubes / Valves 2 22nd September 2007 09:17 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 07:29 PM
Aleph 2 - thermal connections MEGA_amp Pass Labs 6 21st December 2004 11:53 AM
Copyright ©1999-2017 diyAudio
