F5 For Low Z Loads ?
Old 11th February 2011, 11:54 PM   #21
flg is offline flg  United States
flg's Avatar
Originally Posted by eyoung View Post
could you not add a serial R or RC to the speaker or OP to give the amp a more hospitable load to drive...???
Just a thought, EL
Well, No, would be my easy answer. That would change Qts, I guess, and muck up the bass responce.
But, let's explain it this way. I have 16 8 ohm speakers in 8strings of series pairs. 2 ohms. Because, it is said that even more than 1 speaker in series will cause one to suffer ill effects from the back emf of the others. I personally could not explain or understand that concept except to say that I find it less important of a problem if there are only 2 in series. I believe the paralell inductance of the group will also be lower making for an eaiser load on the amp. Additionally, less voltage gain is needed due to the lower output Z Speakers allowing less chance for the signal to be hosed up...
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 12th February 2011, 06:26 AM   #22
Melon Head is offline Melon Head  Australia
Banned
Originally Posted by Zen Mod View Post
just an idea - there was similar or exactly same idea recently - why not combine F5 and F4 ?
something as mini F5 - same front end , but with nice 2SJ76/2SK213 "outputs" ..... say 100mA of Iq ...... driving multiple Toshiba final outputs in common source ;
so - count it as 2,5 stages ........
Originally Posted by Melon Head View Post
Speaking of different.
How about this one?
Edit: I was too lazy to add the gate resistors
I would go with your original idea first. As Nelson says two pair is enough.
I built up three a pair version a long time ago now, so it can be done, no problem.
Go for it
Old 13th February 2011, 01:37 PM   #23
flg's Avatar
So, where was I... A few pics are in order. I actually thought I would be raising more questions too? Once I decided to change the output configuration, I'm opening somewhat of a can of worms with the sound and the original design. It's difficult to judge How much things will change the sound or where I should be correcting for the changes. So far my changes are: 19V rails rather than the stock 24V, Dual output Toshiba FETs with .27 ohm Source Rs. in the output. And, the low Vgsth of the Toshiba's will require a smaller Drain R in the input stage to maintain the correct bias, I'll go with 620 ohms for now and stay with the 5k pot. With the lower Vds on the output transistors, I should be able to up the bias beyond the 1.3A stock value (2x of coarse) maybe as high as 1.6A/FET.
Lets see, 1st pic is a H.S. from HeatSink USA. 10.08" x 8" (200mm) section. This should be good for around .35C/W but we'll see. Bias is adjustable to optimize for available dissapation.
Second pic is the back of the H.S. with the mostly stuffed CViller board set up for dual outputs. FET holes are drilled and tapped, just gotta do some board mounting and H.S. mounting holes.
Last pic is 1 of the Antek 400VA 2X15 transformer(1/ch).
Old 13th February 2011, 02:03 PM   #24
flg's Avatar
And...
Old 13th February 2011, 06:50 PM   #25
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by Nelson Pass View Post
Of course the problem is not driving, say 100 watts into
1 ohm, which implies 12 watts into 8 ohms. The problem
is that people with 1 ohm loads want a couple hundred
watts into 8 and over a kilowatt into 1. Even that's
do-able, but they want it to sound good also.
Since meeting demands like this requires a lot of hardware,
it's prudent to define what you actually want in advance.
50Watt @ 8 ohm with good sound will do ...
I recall that the ill fated Pass Monster project died out
just after I delivered a preliminary schematic.
Hmmm... the revival time might be upon us .........
Go for it
3 pr's with the standard front end or with cascoded front end ? ..
Old 13th February 2011, 07:16 PM   #26
flg's Avatar
Well, because of the loss of gain by a factor of 4 in the output stage, when driving 2 ohms, 2 pair is necessary. Smaller Source Rs will help to a small degree. But, 3 pair would probably regain a similar gain figure to the stock F5. I'm willing to go the easy route for now. The CViller board is set-up for 2 pair of outputs.
As far as power, my goal was to drive 2 ohms relatively well. At 1.3A/FET, I should be getting over 25Wrms max output into 2 ohms. At 1.6A/FET, I'm doing over 40Wrms. On a speaker with over 100db efficiency that's more than I'll need.
Old 13th February 2011, 08:13 PM   #27
Banned
Both standard and cascoded. However I used IRFP devices.
Old 13th February 2011, 08:33 PM   #28
woodturner-fran is offline woodturner-fran  Ireland
I tried both of my f5 amps with my stacked quads - they didn't play nice together.......
the highs had a touch of harshness that isn't in the amp with other "normal" speakers. But the main thing was that every now and then the source resistors would smoke on the f5. 9 times out of 10 it would be fine then on the 10th they would go.
I couldn't figure it out - not usual stuff like plugging cables when powered etc.
Fran
Old 13th February 2011, 09:21 PM   #29
Sin Bin
Fran
Instability ?
Old 13th February 2011, 09:24 PM   #30
Could be....... any suggestions for checking this out?
F5 For Low Z Loads ?Hide this!Advertise here!
Class D and Very Low Impedance loads Bruno Putzeys Class D 35 23rd March 2015 03:12 AM
Threshold S/500 stable at low loads? RobertS61 Pass Labs 18 23rd November 2010 10:50 PM
LM3886 & low impeadence loads vinodk Chip Amps 6 21st May 2010 03:12 AM
Driving Low Impedance Loads weinstro Solid State 14 8th May 2005 09:53 PM
