#31 | |
Banned
Check that all your interconnected equipment is not creating a ground loop with your amp. Also check the amp itself for correct grounding. |
#32 |
Mine acted the same way with the inputs shorted and nothing connected to the amp other than a power cord. The offset is set by balancing a constant current source against a constant current sink. The slightest air movement would throw the balance off. Moments after someone walked by my bench everything changed.
It boiled down to noticing how much the offset drifted when I opened the case and adjusting to that amount from zero. |
#33 |
I do have a scope. Haven't had it hooked up while setting the offset but it never displayed any evidence of oscillation before. I did check it a couple weeks ago so there was no reason to suspect a problem. At this point I'm just trying to tame this beast. It probably gave me fits when I built it 15 years ago too. But being new it was probably a little more tame. I just blocked out that memory. I just reworked the grounding,moving the star ground from the main cap plate to a star point next to the power supply where everything is tied together. I suspected maybe a grounding problem too but this change didn't make a difference. If .3V is the most I can set across R7,8 I guess I'll just live with it. Back to the bench.
#34 |
.3V across R7/8 is rather low - only 6 mA in the VAS to drive the output stage. Are you saying you can't adjust it higher at all or aren't able to adjust it higher AND keep the offset under control?
#35 |
I can adjust it higher but the offset is all over the place. The higher the R7,8V, the hotter it runs and the more unstable it gets. If I even move my hand or the screwdriver close to the circuit it goes nuts.
#36 |
Sounds about right. As it gets hotter you need to give it more time to stabilize. Offset will change once the output stage heats things up.
#37 |
ok. I hooked up the scope to watch the signal on the output. It's not perfectly flat but the funny thing is as soon as I connect the scope to the output the DC drops right down to about 5-4 mv and is stable.. Getting late but tomorrow I'm going to check the other side for comparison.
#38 |
Banned
#39 |
There are MANY gaps in my knowledge. Can you explain why strapping a few megohms across the output would make it stable? I can see how if the input differential had no DC path to ground it would cause all sorts of drift, but I can't wrap my head around how the output would do the same. Thanks.
#40 |
I'm confused. when I look at the traces on the front end PCB there are 2 connections to circuit ground...1 for right and 1 for left right between the Output and -DRV connection. If you follow the traces they're not independent of each other, which suggests only 1 should be connected. connect em both and whalla...ground loop? I don't see the same issue with the ground connection terminals for the output zobel. Am I mad? Been at this a long time and I could be losing it. Connecting one side at a time I can dial everything in. Connect em both and it's a crap shoot.
Comments? |
| FS: Pass A75 PCBs | mdlover | Swap Meet | 1 | 13th July 2007 01:52 AM |
| Pass Tharagard A75 vs Pass Aleph 1.2's | daly41k | Pass Labs | 7 | 18th February 2007 03:10 PM |
| A75 question for Mr Pass | demons_wing | Pass Labs | 13 | 25th April 2004 08:21 AM |
| Pass A75 nearly finished! | harbin | Pass Labs | 3 | 21st August 2001 11:37 PM |
| Pass A75 Oscillations? (long) | harbin | Pass Labs | 8 | 16th August 2001 02:26 AM |
