How to build the F5 - Page 94 - diyAudio
Old 9th August 2012, 08:39 AM   #931
Ok, thanks.
But I'm just wondering - will all the values suffice if I put a 300VA transformer for single channel?
Or do I have do change something, since it was designed for one transformer, not a dual mono build?
Old 9th August 2012, 09:37 AM   #932
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
300VA /channel - more than good
C bank ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 9th August 2012, 09:44 AM   #933
JojoD818's Avatar
Originally Posted by Tehtoril View Post
Ok, thanks.
You do not have to change anything...
Old 9th August 2012, 09:53 AM   #934
AndrewT is online now AndrewT  Scotland
For a dual mono arrangement, I recommend that each transformer feeds a dual bridge rectifier and that each channel have it's own quite separate Main Audio Ground (MAG).
Then after testing each channel individually, you work out how to connect your two MAGs to the Chassis to make your amplifier user safe.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th August 2012, 12:13 PM   #935
dual mono F5 with dual rectifiers pr ch.
225VA 2*18V pr ch.
PSU PCB's is from chipamp.com
Old 9th August 2012, 12:16 PM   #936
Audio,
that looks like 4 diodes feeding the cap bank. 4 diodes = 1 bridge rectifier.
Are there 8 diodes in there that I can't see?
Dual rectifier for a dual mono needs 16 diodes, i.e. 4 bridge rectifiers.
regards Andrew T.
Old 9th August 2012, 12:24 PM   #937
andrew. the diodes is jumped. i use seperate bridges
Old 9th August 2012, 12:27 PM   #938
Ah, that must be the gaggle of wires going into the hidden gems behind the transformers !
Can you show the grounding schematic for the dual mono? Or is it already posted?
regards Andrew T.
Old 9th August 2012, 12:35 PM   #939
thats right the GND from each ch goes to earth thru a CL-60 pr ch.
(don't mind out of phase connection on one of the bridges. this was sorted right after the pic was taken)
Old 9th August 2012, 12:41 PM   #940
What "out of phase" connection?
I can't see it.
Could you explain?
regards Andrew T.
Another F5 build--beautiful music, different drummer CanAm Man Pass Labs 144 7th March 2013 09:41 PM
Transistors and Resistors for F5 Amp Build NYCOne Swap Meet 0 20th December 2010 04:29 AM
Next suggested build after F5 anilva Pass Labs 36 3rd December 2010 04:11 AM
F5 Build Instructions 1108 Pass Labs 4 12th May 2009 10:58 PM
Planning an F5 build - some beginner questions njepitt Pass Labs 144 15th March 2009 11:55 PM
Copyright 1999-2017 diyAudio
