How to build the F5 - Page 55 - diyAudio
Old 26th March 2011, 04:05 AM   #541
eyoung is offline eyoung  United States
eyoung's Avatar
or cause earthquakes and tsunamis....Be careful very careful...
mE
"Lead me not into temptation...I can find it myself."
Old 26th March 2011, 04:11 AM   #542
mE
....or the New York Mets may win the 2011 World Series.....
Be verrryyyy careful..... "Run away..... Run away home..... Run away home" (Monte Python)
Old 26th March 2011, 04:13 AM   #543
Banned
Shuld I post or shuld I not
If I post I be in truble...
Oh well please telme to shut the Fet up I can take it...
Could you Please let me know if I am welcome to post here?
Old 26th March 2011, 04:41 AM   #544
Bksabath......
Post away, amigo...... you are among friends here....!
Old 26th March 2011, 04:48 AM   #545
6L6 is offline 6L6  United States
6L6's Avatar
Bksabath - You are building an F5, right? That's what this thread is about!
I'm still curious if you are going to use the biscuit tin as a transformer cover...
Old 26th March 2011, 04:50 AM   #546
eyoung's Avatar
Ditto your post' are interesting and amusing, so post away my friend...
mE
Old 26th March 2011, 05:02 AM   #547
Banned
Okey dokey
Fell so much beter tanks
Woody
Ken is right about the limits and 40W is the going figure.
But is also trou that Papa said 1 They sound better at 2 amps and also They sound beter at higher voltagge
So the only way to get both is to improve the heat exchange process
Big heat sinks but slow in setling or Goop and mica versus Kerafol
Also Kerafol work beter with higher pressure so how much torque could you put on a screw before you strip the tread?
Bit like F5 racing port flow by hand wok best
One more question did you Ken / 6L6 mannage to get a temperature on the CL60
Old 26th March 2011, 05:16 AM   #548
Banned
6L6
Biscuit tin is a definite possibility it does work.
I am not shure if I will have to as on my case the PSU is practicaly in a separate enclosure so I am more on the no need for it and cooler trafo at the moment.
In your case IMO is worth a try
Old 26th March 2011, 05:17 AM   #549
6L6's Avatar
Using the extremely accurate pseudo-pscientific method of touching them and guessing, I would say that mine are in the neighborhood of 120-130F. (49-55C)
Very warm/hot to the touch, but not going to burn you, and able to touch for 5-10sec.
Old 26th March 2011, 05:22 AM   #550
Banned
6L6
Tanks for temperature.
eventualy I will have to pull 2 maye 3 times the current as I got 4 homs speakers so mine will be much worst.
Question
your therminal block is rated at 80 C ?
May get britle 6 months down the line.
Another F5 build--beautiful music, different drummer CanAm Man Pass Labs 144 7th March 2013 10:41 PM
Transistors and Resistors for F5 Amp Build NYCOne Swap Meet 0 20th December 2010 05:29 AM
Next suggested build after F5 anilva Pass Labs 36 3rd December 2010 05:11 AM
F5 Build Instructions 1108 Pass Labs 4 12th May 2009 11:58 PM
Planning an F5 build - some beginner questions njepitt Pass Labs 144 16th March 2009 12:55 AM
Copyright 1999-2017 diyAudio
