How to build the F5 - Page 52 - diyAudio
Old 25th March 2011, 03:26 PM   #511
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by sts9fan View Post
I have built a point to point PS for my F5.......
Kris
try with bulb in series - measure voltages at caps
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th March 2011, 04:05 PM   #512
6L6 is offline 6L6  United States
6L6's Avatar
I cannot find anything wrong but I keep blowing fuses with no load on the PS.
Are you absolutely sure you have the transformer primaries wired correctly? That will pop a fuse every time...
Old 25th March 2011, 04:08 PM   #513
sts9fan is offline sts9fan  United States
pretty sure. It does not pop until I reach 40VAC with my variac. Plus like I said I had someone check it out. Without the returns connected together on the last caps I get 24V across each cap.
Old 25th March 2011, 04:11 PM   #514
6L6's Avatar
Hmmm... Interesting.
Can you post some photos? That would help immensely.
Old 25th March 2011, 04:15 PM   #515
I will post some when I get home. I am gonna try the light buld also.
Old 25th March 2011, 07:09 PM   #516
Andersonix's Avatar
Sts9fan: What value of fast blow fuse are you popping? (I remember most of NP's PS diagrams showing a slow-blow fuse.)
Old 25th March 2011, 07:39 PM   #517
6L6's Avatar
Adding thermistors is fairly easy and part of the final design, you might as well do it now and see what happens.
Also, the slo-blo fuses might alleviate your problem. But if you are turning things up slowly on a variac, that probably will not help.
Old 25th March 2011, 08:03 PM   #518
I have blown up to 6A fast blow. Also I do have the thermistors on the mains. I was thinking of adding some to the rails.
Old 25th March 2011, 08:21 PM   #519
6L6's Avatar
That's weird.
Post pictures. (Yes, I know you said you would... just reiterating!)
Old 25th March 2011, 08:29 PM   #520
Andersonix's Avatar
Can you confirm: So even with a Variac ("temporary soft-start") and CL-60s on both primary legs, you are still blowing the 6A FB fuse at +/-24VDC voltage on the >unloaded< PS?
Another F5 build--beautiful music, different drummer CanAm Man Pass Labs 144 7th March 2013 09:41 PM
Transistors and Resistors for F5 Amp Build NYCOne Swap Meet 0 20th December 2010 04:29 AM
Next suggested build after F5 anilva Pass Labs 36 3rd December 2010 04:11 AM
F5 Build Instructions 1108 Pass Labs 4 12th May 2009 10:58 PM
Planning an F5 build - some beginner questions njepitt Pass Labs 144 15th March 2009 11:55 PM
Copyright 1999-2017 diyAudio
