How to build the F5 - Page 51 - diyAudio
Old 25th March 2011, 12:43 PM   #501
I have been contemplating such a design but everyone here frowns on using off line supply's. jer
Old 25th March 2011, 01:05 PM   #502
Originally Posted by Lerg View Post
Isn't each output device biased to 1.3A? Doesn't that mean that you are drawing more than 5.2A from the transformer?
In the F5 manual the amp as per Firstwatt a stereo F5 pulls about 180W from the wall, so for fun lets assume that the transformer has to provide about 160VA with a 1.3A bias per output device due to losses and such. That means you are drawing around 9A from the transformer at stock bias.
Lerg,
there's something seriously wrong with your numbers !
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th March 2011, 01:07 PM   #503
Send a message via Yahoo to kannan_s
Originally Posted by 6L6 View Post
Here are the photos of the initial powerup and the final tweaking/tuning.
And as NP said, "...And there you have it!!"
Oh, the Hiaku -
Building the F5
In solder fumes I smile
heat and balance sings
Or, if you are into 3-5-3
Pass amps are
in their special way
his and mine
Hi where did you buy your heatsinks ?
thanks
kannan
Old 25th March 2011, 01:31 PM   #504
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Originally Posted by CanAm Man View Post
6L6, Jim (and Woody, etc)......
I dug a litte deeper into Antek's published specs for there 18-0-18 VAC torroid core transformer families. All data I used is from the Antek website. I've plotted the data in the attached. The info for the smaller transformers (100, 200, 300 VA) is mostly FYI. Please note that for each VA model I've plotted the three data points in the Antek specs, except for the 500 VA model, where the third data point (for the most heavy current load) was clearly erroneous.
Some interesting observations. The 500 VA model, based upon Antek's own data, is not a strong candidate for the F5, considering it's cave-in under loads; a little surprising for a claimed 500 VA model. Note that the Antek data suggests the 400 VA and 600 VA models are ALMOST IDENTICAL in VAC/current specs, to include voltage sag under load, up through the "expected" operational range for a straight-forward F5. (I'm certain some will chose to debate what "expected" operational range ought to be, but I'm considing that to be about 10 amps/rail, and close to the stated 18 VAC secondary. For those who want to debate, please feel free to start a new thread).
Also note the "blue dot", at about 18 VAC and ~3 Amps--that's where my curent 400VA transformer is working......pretty far below the Antek data for that model.
In any case, enjoy. All, FYI..... Again, all the "hard data" is from Antek itself. I'd be interested in others' thoughts........
Ken
Should I replace my antek 4218?
Old 25th March 2011, 01:41 PM   #505
Well, the 600va is fine. I am quite lucky that I bought one that was "too big". No worries, no wondering if it's going to work. It's quiet, it's cool.
I'm sure the 500VA will also work, I've recently bought one and will be reporting any problems. Inasmuch as several have built with them using the 300VA for a stereo amp without problems, (and, while there is a lot I dont understand here), I dont see how the 500VA is less than a candidate for the
300VA model would be.
I should say outright that my only experience with Antek is the dual 300VA units in my F-5, which are hum/buzz free and have done a fantastic job as far as I can tell. (with no way to really measure its performance).
I think the original F-5 uses a single 250VA? Trying to find where I got this info as we speak, I thought it was the F-5 article on the Firstwatt site.
Would be nice to see them and a few others measured in a similar fashion, so we could see how they perform.
Russellc
Old 25th March 2011, 01:50 PM   #506
Are you having any problems with it? Is it making noise? Does it get way too hot? If not you likely have not a thing to worry about. I'm doing a build right now with the suspect 500VA model. I have every confidence in it. That said, I will find out. The Antek stuff has been widely used and I'm not aware of any problems here or elswhere, but there sure could be.
They are, by a good margin priced lower than most of the competition, I'm willing to admit their could be quality differences between these Anteks and Plitron or Avel-Lindberg as well.
I dont have a lot of testing equipment, but would help with any testing anyone would like performed on this unit.
It would be nice to have the folks at Antek weigh in, bit oh well.
I will report back any failings of this unit as used with F-5.
Russellc
Old 25th March 2011, 02:22 PM   #507
Courtesy of Decibel Dungeon -
Use a incandescent lightbulb, obviously...
Old 25th March 2011, 02:45 PM   #508
Russellc
I'm still in the process of putting it together.
Old 25th March 2011, 02:56 PM   #509
sts9fan is offline sts9fan  United States
I have built a point to point PS for my F5. I have two large 68000uF caps on each rail in a CRC. I cannot find anything wrong but I keep blowing fuses with no load on the PS. Is it possible that even witht he CL60 the inrush is too much? I had fast blows so I ordered some slow blows. I had an EE check my work and he said everything looked fine but could be inrush and suspected at steady state things should be fine.
Can I add thermisters to the rails? How can I test this hypothesis? My Transformer is a Antek 300VA.
Kris
Old 25th March 2011, 03:14 PM   #510
Good question. I'll be talking to Antec about my 400VA model......
In any/all cases, I found their tech data to be very interesting.......!
Probably the best is to listen to the amp, and see if you like what you hear. (Of course, without an identical amp with a bigger VA transformer, it will be a "one-deep blind test".....)
Another F5 build--beautiful music, different drummer CanAm Man Pass Labs 144 7th March 2013 09:41 PM
Transistors and Resistors for F5 Amp Build NYCOne Swap Meet 0 20th December 2010 04:29 AM
Next suggested build after F5 anilva Pass Labs 36 3rd December 2010 04:11 AM
F5 Build Instructions 1108 Pass Labs 4 12th May 2009 10:58 PM
Planning an F5 build - some beginner questions njepitt Pass Labs 144 15th March 2009 11:55 PM
Copyright 1999-2017 diyAudio
