How to build the F5 - Page 112 - diyAudio
Old 3rd November 2013, 04:30 PM   #1111
KatieandDad's Avatar
Well the F5 is cooking nicely, the heatsinks are more than adequate and they are barely warm after nearly an hour.
Bias is hovering around the 0.6V mark and the output offset is about 1-3mV.
Old 3rd November 2013, 05:28 PM   #1112
After three hours of cooking offset has stabilised at 0.5mV and bias at 0.6V. Can't better that.
Old 4th November 2013, 02:51 PM   #1113
Well I've finally finished the project.
Now when I turn on the amp from cold I get an offset of about 30mV, after a few minutes of warming up that comes down to about 6mV, then it fluctuates between +6mV and -6mV but only on one channel ?? The other channel is stable.
Any ideas..
Old 4th November 2013, 02:58 PM   #1114
I've just tweaked the bias to bring the offset back down to close to zero and it seems to have now stabilised ??
Is it normal to have a bigger offset when first turned ON.
Old 4th November 2013, 03:01 PM   #1115
6L6 is offline 6L6  United States
6L6's Avatar
Just to clarify, you say it's fluctuating between +/- 6mV? 0.006V?
That's so low as to not matter, and anyway, apply a signal and it will fluctuate much more than that.
Essentially you are down in the noise that can only be fixed by lead dressing and the like. I'm sure Andrew will suggest twisting your leads and such.
Your build looks fantastic, I would button it up and listen to it for a week and then re-check the bias and be done.
Congratulations!!
Old 4th November 2013, 03:05 PM   #1116
6L6's Avatar
Yes, very much so.
The little thermistors near the power Mosfets are part of a temperature compensation circuit for the bias, and they try to keep the bias stable as things heat up, but they can only do so much. That's why Nelson suggests making the final adjustments to the bias once it's been on at least 1/2 hour.
Old 4th November 2013, 04:31 PM   #1117
Default All dressed up and ready to go.
The final product. Unfortunately I can't connect it up as I haven't got long enough interconnects yet.
Old 22nd November 2013, 06:37 PM   #1118
Default argh!
Hey guys,
Any thoughts on why the full bias voltage would show up at the outputs (DC offset)? ...done tons of reading. just haven't come across this particular f5 snafoo.
Mosfets are toast, aren' they?
6l6, thanks for these excellent build guides!
Old 22nd November 2013, 08:17 PM   #1119
6L6's Avatar
You have a short somewhere - or a Fet in the wrong position. Or both.
Please take well-lit, in-focus photos and we will take a look.
Old 26th November 2013, 04:43 PM   #1120
Default Board Images
Here are a couple shots of my board, as well lit as I can manage in my dungeon.
I believe my Fets are correctly positioned and I don't see any shorts.
I have found that Offset rises faster than Bias until .3-.35Volts (Bias). After that point DC offset levels off around .4volts and I can continue to increase bias.
Your help is very much appreciated.
Happy Turkey Day to those of you in the states.
Another F5 build--beautiful music, different drummer CanAm Man Pass Labs 144 7th March 2013 09:41 PM
Transistors and Resistors for F5 Amp Build NYCOne Swap Meet 0 20th December 2010 04:29 AM
Next suggested build after F5 anilva Pass Labs 36 3rd December 2010 04:11 AM
F5 Build Instructions 1108 Pass Labs 4 12th May 2009 10:58 PM
Planning an F5 build - some beginner questions njepitt Pass Labs 144 15th March 2009 11:55 PM
Copyright 1999-2017 diyAudio
