How to build the F5 - Page 104 - diyAudio
Old 17th August 2012, 03:04 PM   #1031
Originally Posted by hangguy View Post
I was using a couple general purpose GBPC-3510 for my F5 build. Recently, I decided to change them out and use 8 pcs of MUR3060 to make up the rectifier. This change brought some noticeable improvements over the GBPC-3510. The most apparent are the detail levels improvement and the image solidity. For the $30 I paid for the MUR3060, this is a very worthwhile upgrade for any F5 builds.
I also used the MUR 3060 and had great results, I didnt have any "glare" that a few have complained of, and have often felt that these rectifiers, and the use of the IRF devices and their known second harmonic distortion were partly responsible for my very sweet sounding F-5.
Hearing Andrew and others bring up snubbers, (which I have seen used to great effect on the output transformers of tube amps) I thought I would inquire. Sorry if anyone is that sensitive, I'll continue using my MUR 3060s. As to A.Wayne's comment,
Trust me, if I want to get smart with anyone, there will be no doubt. Just trying to learn, sorry to those put off by the inquiry!
The only thing I didnt like about the MUR devices is the multiple solder points involved, and positioning the pads under all 16 of them!
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 17th August 2012, 04:09 PM   #1032
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by Russellc View Post
No, not at all, I thought he was saying this because he had done it this way in an F-5's power supply. That's why I inquired about the values. Apparently
this is not the case just a statement that typically he uses the snubbers. Why what are you trying to make of it?
Russellc
Nothing , i left of the smiley
Old 17th August 2012, 04:20 PM   #1033
hangguy is offline hangguy  United States
Originally Posted by a.wayne View Post
Did you do any matching ?
No, I didn't. Do rectifier diodes need to be matched?
Old 17th August 2012, 05:02 PM   #1034
Sorry then, maybe I'm the sensitive one! I'm needing to go back to the Hagerman site and study up on the snubbers, I will try them in place of the MURs, they were not cheap! Snubbers worked well in the output transformers
I was talking about, I've no idea how the values are calculated, I'll sort it out. I'm trying to make this next F-5 a little more modular, so various things, like rectifiers can be experimented with...I've only built one pass power amp so far, so nothing to really contrast it with.
I am also building a turbo, whose heatsinks will allow me to also try BA 2 and BA 3 boards, and I would like it to be easily switchable as well. Once that is done, I am planning on (and have a parts pile beginning) for an Aleph 2, but it will require two for the mono obviously. The Aleph will be built to stay as they are, but the others can be more like platforms to try different things.
Russellc
Old 17th August 2012, 05:18 PM   #1035
I didnt match mine either...they were from the same batch, in a tube like thing, everything measures well so I guess I was lucky?
Russellc
Old 17th August 2012, 05:42 PM   #1036
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
no need for diodes matching
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 17th August 2012, 06:31 PM   #1037
I thought he was saying this because he had done it this way in an F-5's power supply. That's why I inquired about the values. ..........a statement that typically he uses the snubbers. .............
yes & no.
The snubbers are part of the PSU to damp the PSU response such that transients don't promote instability in the PSU. This is all based on the transformer and the rectifier diodes. It has virtually nothing to do with the F5 or any amplifier hung on the output end of the PSU.
Design the snubbers for the PSU. Do not design the snubbers for the F5.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th August 2012, 07:49 PM   #1038
Sin Bin
Originally Posted by AndrewT View Post
yes & no.
So a SS class-a amplifier benefit from snubbers in the PSU .... ?
Old 18th August 2012, 09:43 AM   #1039
Yes. The snubbers help attenuate the spikyness in the supply.
All amplifier types benefit from a cleaner supply.
regards Andrew T.
Old 4th March 2013, 12:59 PM   #1040
rade95 is offline rade95  United States
Hi guys, like the other diy-er, I also have a problem adjusting F5 BIAS on one of the channels. Only turning P1 makes voltage rise on R11 and R12 while turning P2 makes almost no difference. I power on with 2 turns on P1 and P2, then turning P1 and P2 by 1 turn at the time, makes voltage rise on R11 and R12 but not equally. I noticed that turning P2 makes both voltages stays the same. If I have say 0.35V on R11 I get about 0.53V on R12. P ch MOSFET IRFP9240 gets hot really fast at about 0.5V and R11 starts getting hot, also R12 but not quite as hot. The voltage on R12 is almost twice that on R11 but the N ch MOSFET stays almost cool. Has anyone seen these symptoms before. Could it be that the P ch JFET (P1086), or the N ch MOSFET (IRFP240) maybe bad? Any advise would be appreciated.
UGS pre, stock F5, PassLabs X2.5, Aleph P
Another F5 build--beautiful music, different drummer CanAm Man Pass Labs 144 7th March 2013 09:41 PM
Transistors and Resistors for F5 Amp Build NYCOne Swap Meet 0 20th December 2010 04:29 AM
Next suggested build after F5 anilva Pass Labs 36 3rd December 2010 04:11 AM
F5 Build Instructions 1108 Pass Labs 4 12th May 2009 10:58 PM
Planning an F5 build - some beginner questions njepitt Pass Labs 144 15th March 2009 11:55 PM
Copyright 1999-2017 diyAudio
