How to build the F5
How to build the F5
Old 8th February 2011, 03:21 AM   #1
6L6 is offline 6L6  United States
6L6's Avatar
How to build the F5
Default How to build the F5
...Well, this thread will be how I build mine.
Nothing out of the ordinary, Peter Daniel boards, single transformer, Tech-DIY transistors and other bits, HiFi2000 chassis.
I have collected all the pieces and finally today the chassis arrived from Italy! I am ready to start!
Here is the obligatory "armory" photo. Only one of the amp channels shown.
The rear panel. I thought I ordered an Inlet Module with a switch, but I didn't read the datasheet well enough, and it has a neon light power indicator instead. Oh well. Luckily I have a couple of nice bat-handeled switches, I will use one here. The Jacks and RCAs are also from my box, I think they are Vampire.
Here are the contents of the Tech-DIY F5 kits, the Peter Daniel's boards, and a couple of silpads. I also have micas and grease, I will most likely use those.
The PSU components. Vishay rectifier blocks, Peter Daniel PSU board, resistors, 33,000uf capacitors, CL-60 thermistors, and a big-honkin' 600VA transformer.
When I was determining the transformer size necessary I must have had a brain-sneeze, I must have only thought of one secondary! Oh well, it was only $20 more than the 'proper' (400VA) size. The 4-pin caps will work on the board with just a bit of modification.
If you were wondering, the Peter Daniel boards are very small. Also very nice!
That's it for now, I will post more photos as I progress.
Old 8th February 2011, 04:11 AM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
How to build the F5
Well there you have it.
Old 8th February 2011, 04:59 AM   #3
6L6's Avatar
How to build the F5
Not quite yet. Gimme a little time...
Old 8th February 2011, 03:55 PM   #4
Marra is offline Marra  United Kingdom
How to build the F5
Good luck with the build you'll enjoy it went its finished. Mine has been in use for the past couple of days and to be quite honest has been worth the effort; sounds pretty good. I was expecting to have to turn my DCB1 up to max after using an Aleph 5 but the difference in setting is minimal.
HiFi 2000 make good kit don't they. I used there front; top and base panels with sinks sourced in the UK; should just have bought one of there full kits.
Setting the trim pots threw me to start with; I had'nt realised that there interaction would be so intimate.
Old 8th February 2011, 04:26 PM   #5
Andy5112405 is offline Andy5112405  United Kingdom
Banned
You've obviously put a lot of thought into the choice of components and the case. Why use such an agricultural ON/OFF switch ?
I've got a similar thread running with my F4 build. Even though my ON/OFF switch is hidden at the back of the amplifier I have taken a bit of trouble to make it look nice.
The rear view
http://img808.imageshack.us/img808/594/dscf2361c.jpg
I used a Personal Computer ON/OFF push switch that will cope with the high transient currents of massive Toroidal Transformers.
This is the case before painting and filling.
http://img109.imageshack.us/img109/82/dscf2363p.jpg
Old 8th February 2011, 04:37 PM   #6
6L6's Avatar
How to build the F5
Well... I'm actually not married to using that switch. It does have a very nice feel, however. And it will be on the back, so nobody will ever see it.
I wouldn't mind a blue-ringed flush pushbutton, but I haven't the foggiest notion of where to find one. That would look nice on the front panel.
And, when it's all said and done, the switching will be done on a power conditioner, not the amp itself. So having the switch in back (which was always the plan, even with the Inlet Module) will not be an issue.
Old 8th February 2011, 04:45 PM   #7
Banned
Have a look at http://www.rs_online.com. They do a very nice line in illuminated push switches. The Pass Amps and their hefty power supplies need a meaty ON/OFF switch. My F4 is using 2 x 500VA transformers which need a decent 10A 240V switch.
Old 8th February 2011, 04:54 PM   #8
michal is offline michal  Canada
Try eBay, plenty there, but expensive...
Are you switching more than 1 power hungry device with the power conditioner? Watch out for in-rush current. You can try using older style under CRT monitor power managers, that have dedicated switch per outlet.
I see you are not a big fan of fuses...
Going to be a nice looking build.
Old 8th February 2011, 05:11 PM   #9
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
How to build the F5
same case ,different amp ; few pics - maybe some of these will be useful
Babelfish J za hifish-a - diyaudio.rs
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 8th February 2011, 05:35 PM   #10
6L6's Avatar
How to build the F5
Actually, if you put one big draw on the main switch, and the other big draw on a timed switch (which my conditioner has) it's not a problem.
I see that you are not familiar with fused power inlet modules...
Thanks, I am hoping so!
How to build the F5Hide this!Advertise here!
Another F5 build--beautiful music, different drummer CanAm Man Pass Labs 144 7th March 2013 10:41 PM
Transistors and Resistors for F5 Amp Build NYCOne Swap Meet 0 20th December 2010 05:29 AM
Next suggested build after F5 anilva Pass Labs 36 3rd December 2010 05:11 AM
F5 Build Instructions 1108 Pass Labs 4 12th May 2009 11:58 PM
Planning an F5 build - some beginner questions njepitt Pass Labs 144 16th March 2009 12:55 AM
