no frying , no Herr Mueller , sweetspottier
read F3 article
Zen Mod what is your point? I read F3 and ZM #8 articles. I am not talking about SE Class A JFET/MOSFET amp, but PP Class AB amp. To my knowledge FW hasn't designed such an amp yet, PassLabs did, several in fact. If I missed FW design or if this has been discussed in some other FX threads, pls point me to the thread, but F3 or ZM #8 is _not_ what I am looking for.
No problem, if you can point the page where this was discussed I would appreciate it. I want to have a lower bias but higher +- rails, that would make MOSFETs work in class AB switched mode, producing more power. I doubt that this can be done without having a new driver stage.
Stupid question, but its taking me way to long to search up the answer:
Where on the schematic does r35 and the led go? Can i use any led and a 50k trimmer pot to adjust the light to my taste? I like them dim. I´m making my ft p2p wired, and the picture of the board tells me to little.
Also the original schematic differs quite a lot from the one in the store now. What are the big difference in functionality?
Again, I know these questions are stupid, there is just to much irrelevant information out there.
Thanks!
Thanks!
Thanks!
There's even another different F5 schematic in the F5 Turbo manual which I think is the latest version.
Pot. P3 is added to tweak input symmetry for lowest distortion.
The input resistors R1&R2 are new values and configured differently. Thermistors TH1&TH2 are not connected to the rails. Not sure what those changes accomplished. Probably subtle differences.
That is what I´m talking about. Why are we doing this? Have searched for a while now. The blog only mentioned the cascoding and more output mosfets. I´m bulding the standard first.
Do you know any place in trondheim to get sheet aluminium and aluminium angles, by the way?
Look at post 930 in this thread
The post before it has a excel spreadsheet but my virus protection blocks it.
There isn't.
However, the community would be very grateful if you made one...
Well since I have to do the foot work with Mouser anyway maybe I can give their bom program a shot. As long as I get feed back from the community if something isn't right so it can be corrected for future folks as my self.
- How to build the F5
