How to build the F5
How to build the F5
Old 13th August 2012, 02:43 PM   #1001
Russellc is offline Russellc  United States
How to build the F5
Originally Posted by 6L6 View Post
I agree.
The single PCB is going to be cheaper than 2 boards, obviously.
However, the discrete diodes and heatsinks for the chipamp.com board are much more expensive than a pair of diode blocks. (The heatsinks are $$)
You could use a single block with the chipamp.com board if you wanted to, and just jumper the pads where the on-board diodes mount.
I eliminated that expense via the daniels diode boards, which allow bolting directly to the amps's floor!
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 13th August 2012, 02:44 PM   #1002
AudioSan is offline AudioSan  Norway
andrew. its a F5. not a chipamp
only the PSU boards is from chipamp. the aleph PSU boards
Old 13th August 2012, 02:50 PM   #1003
Russellc
you can also just hardwire the diodes to the PSU board and use the bottom has heatsink(mounting them under the board) . but then you are again stuck on single rectifier(chipamp's boards). there is lots of ways to do it
Old 13th August 2012, 06:18 PM   #1004
6L6 is offline 6L6  United States
6L6's Avatar
How to build the F5
Remember that Tehtoril has already purchased the Chipamp.com PSU boards.
Old 13th August 2012, 06:23 PM   #1005
How to build the F5
Again, if single rectifiers are used, I would just do it like 6L6 did with the heatsinks, rather than twist it so that the very hot diodes were under the board....oh well, to each their own. I went the full dual mono route, built it for a fraction of the retail unit...nice thing about DIY, you can spend a couple extra bucks and gain a lot, even though it might be cost prohibitive to do it in a business where many unit are produced.
Russellc
Old 13th August 2012, 06:36 PM   #1006
russ. i also went for external rectifiers. in form of bridges. dual bridge pr rail, on chipamps PSU board.
Old 13th August 2012, 06:39 PM   #1007
yes. thats the reason i allways referd to those boards
Old 13th August 2012, 07:18 PM   #1008
Tehtoril is offline Tehtoril  Poland
Thanks for keeping that in mind, guys
So You say, that I should buy 4 bridges?
Wich one would be the best for that job?
Old 13th August 2012, 08:24 PM   #1009
I must be having some "elderly moments".
Of course I'm in an F5 thread. Tell me that again, I'm in an F5 Thread !
regards Andrew T.
Old 13th August 2012, 09:26 PM   #1010
you was refering to chipamp amps. so i started wondering
well. you are in a F5 tread
How to build the F5Hide this!Advertise here!
Another F5 build--beautiful music, different drummer CanAm Man Pass Labs 144 7th March 2013 10:41 PM
Transistors and Resistors for F5 Amp Build NYCOne Swap Meet 0 20th December 2010 05:29 AM
Next suggested build after F5 anilva Pass Labs 36 3rd December 2010 05:11 AM
F5 Build Instructions 1108 Pass Labs 4 12th May 2009 11:58 PM
Planning an F5 build - some beginner questions njepitt Pass Labs 144 16th March 2009 12:55 AM
